Performance & Use
- High-speed VDSL/ADSL Internet access
- Compatible with VDSL, VDSL2, ADSL, ADSL2, & ADSL2+
- Auto detection for universal DSL support
- Easy CD-less installation with Smart Wizard
Fast DSL Internet Access
- Simple and cost-effective VDSL/ADSL modem
- Connect to high-speed DSL Internet access
- Connect directly to a computer or wireless router
The NETGEAR Difference - DM200
- High-Speed DSL optimum performance
- Built-in VDSL compatible with ADSL connections
- Easy setup & Installation—Auto detection Wizard for universal DSL setup
- NETGEAR DM200 - DSL modem
- DSL modem - Ethernet
- Form Factor
- External
- Digital Signaling Protocol
- ADSL, VDSL, ADSL2, ADSL2+, VDSL2
- System Requirements
- UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10
- 4.8 cm x 10.87 cm x 13.246 cm
- 163 g
- DSL modem
- Form Factor
- External
Modem
- Bus
- Ethernet
- Connectivity Technology
- Wired
- 1 - RJ-45 , 1 x VDSL2 - RJ-11
- Cables Included
- 1 x network cable , 1 x phone cable , 1 x phone splitter
- Included Accessories
- Power adapter
- OS Required
- Technical support - 90 days
- 4.8 cm
- 10.87 cm
- 13.246 cm
- 163 g
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
