Operating digital signage has never been easier than with the 46" NEC X461S. This super-slim Full HD LCD display offers LED backlighting technology to deliver high-quality imagery at a lower power consumption than its peers. The industry's first standardized input, the Open Pluggable Specification (OPS) slot, increases flexibility for users in any digital signage application, including video walls where the X461S can be implemented into configurations up to 10 x 10.
- NEC MultiSync X461S 46" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 46"
- Commercial Use
- Yes - digital signage
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- S-PVA
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Sound Output Mode
- Stereo
- Speaker System
- 1 speaker
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- 135 Watt
- Dimensions (WxDxH) - without stand
- 106 cm x 4.3 cm x 61.8 cm
- 20 kg
- 3-year warranty
- Product Type
- 135 Watt
- Diagonal Class
- 46"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS), temperature sensor
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 106 cm
- 4.3 cm
- 61.8 cm
- 20 kg
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Edge-lit LED
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 3000:1
- Brightness
- 600 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.53mm
- Max V-Sync Rate
- 85 Hz
- Max H-Sync Rate
- 91.1 kHz
- AmbiBright, TileMatrix (10 x 10), Rapid Response technology, TileComp, CableComp+, Aspect ratio control (ARC)
Stands & Mounts
- Flat Panel Mount Interface
- 300 x 300 mm
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1360 x 768, 1920 x 1080
Remote Control
- Remote control
Audio System
- Sound Output Mode
- Stereo
- Speaker System
- 1 speaker
- Output Power / Total
- 10 Watt
- External Speakers Amplifier Power (Total)
- 30 Watt
- Speakers
- 1 x speaker - 10 Watt
- Connector Type
- DisplayPort input , HDMI input , DVI-D input , DVI-D output , VGA input , Composite video input , LAN , Serial input , Serial output , Audio input , Audio output , 2 x speakers output
- Expansion Slots
- 1 x Expansion Slot
- Plug and Play, DDC-2B, EN 61000-3-2, VESA DPMS, EN 61000-3-3, DDC/CI, EN 60950-1, WEEE
- Power Device
- Power adapter
- Input Voltage
- On/off timer
- Limited warranty - parts and labour - 3 years
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel with stand - 106 cm x 33 cm x 66.5 cm x 21 kg , Panel without stand - 106 cm x 4.3 cm x 61.8 cm x 20 kg
- Width (Shipping)
- 123 cm
- Depth (Shipping)
- 22.5 cm
- Height (Shipping)
- 79.2 cm
- Weight (Shipping)
- 25.2 kg
- 5 °C
- 40 °C
- 20 - 80%
