NEC E224Wi 22" 1920x1080 DVI VGA DP LED Monitor
Quicklinx: 9SGDWS00 Mfr#: 60003584
NEC's 22" MultiSync E224Wi uses a premium-grade IPS panel, which provides wide viewing angles, outstanding color consistency and image accuracy. Its LED backlighting technology allows a thinner, lighter and sleeker design, as well as higher power efficiency. This EPEAT Silver model includes DisplayPort, DVI-D and VGA D-Sub inputs to connect you to the peripherals. Touch-sensitive controls enable simple display adjustments through the E224Wi's On Screen Display (OSD). Enjoy full ergonomic flexibility with height adjustment, tilt, and swivel and portrait adjustability.
  • XtraView+
    It delivers wide viewing angles of up to 178-degree horizontally and vertically with less color shift and without any glare, reflection or distortion.
  • Carbon footprint meter
    Informs and motivates responsible use of the display by calculating and tracking the conservation of green gas emissions in real time.
  • No touch auto adjust
    It allows the monitor to be automatically adjusted to optimal image settings when initially turned on.
  • Ambix3
    It allows up to three inputs to be connected to a single monitor and for each of the three signals to be displayed with the press of a button.
  • LED backlight
    It provides for industry-leading low power consumption and less hazardous materials.
NEC MultiSync E224Wi - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class B
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Voltage
50.74 cm x 21.39 cm x 36.45 cm
5.9 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, DDC-2B, MPR III, TUV Ergo, PSB, RoHS
3-year warranty
Display Type
Energy Class
Class B
32 kWh
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
31.5 - 81.1 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
ErgoDesign, sRGB colour management, Eco-Mode, NaViSet Administrator, Carbon Footprint Meter, Carbon Savings Meter, TORO Design
50.74 cm x 21.39 cm x 36.45 cm - with stand
5.9 kg
DVI-D (HDCP) , DisplayPort , VGA
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D
Power Supply
Internal
Input Voltage
22 W
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.4 Watt
Dimensions & Weight Details
Without stand - width: 50.74 cm - depth: 5.85 cm - height: 30.11 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
