A top performer for multiple business applications with highest brightness paired with best installation ?exibility and excellent connectivity. The PA600X's special inorganic panels provide for longer operation times and less service cost.
Great picture quality
Even in bright ambient light because of high projector brightness and excellent HQV signal processing. -
Lowest installation cost with high installation ?exibility
Because of 2x wide zoom lens, lens shift, 360° tilt installation and lens centered design. Replace old installation projectors with minimal reinstallation cost. -
Quick and easy network connection
Included many network features for picture transfer and complete cost saving network control by using latest network technology. This technology is also great for PC-less presentation directly from network or from USB memory. -
Enjoy low TCO
By using state of the art technology, inorganic panels and up to 4000h long lamp life thus save the environment and cost by minimizing power consumption, consumables and also service frequency. -
Best brightness ?exibility
By using PA's innovative built-in stacking or edge blending features, when used in combination with other PA projectors! Achieve brightness as high as 20,000 ANSI lumen or extremely large pictures within some minutes with NEC automatic stacking setup application included free of charge.
- NEC PA600X - LCD projector - LAN
- LCD projector
- Built-in Devices
- Speaker
- Brightness
- 6000 lumens
- Contrast Ratio
- 2000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- 330 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), LAN
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI), DisplayPort
- Video Modes
- 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 576/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 443 Watt
- 49.9 cm x 35.9 cm x 14.4 cm
- 7.7 kg
- 3-year warranty
- LCD projector
- Built-in Devices
- Speaker
Projector
- Brightness
- 6000 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 76 cm - 1270 cm
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Max Sync Rate (V x H)
- 120 Hz x 108 kHz
- Bulb type
- 330 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Eco-Mode technology, 3D Reform technology, Micro Lens Array (MLA) Technology, High-bandwidth Digital Content Protection System (HDCP), wall colour correction, Hollywood Quality Video (HQV)
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Keystone Correction Direction
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, DisplayPort, composite video, S-Video, RGB
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
Input Device
- External
- 2 x VGA input - 15 pin HD D-Sub (HD-15) , 5 x RGB input - BNC , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x DisplayPort - 20 pin DisplayPort , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 2 x USB 2.0 - 4 pin USB Type A
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Password protection, control panel lock
- TUV GS, DDC/CI, RoHS, ErP Ready
- Voltage Required
- 443 Watt
- Power Consumption Operational (Standby)
- 0.2 Watt
- Software Included
- Drivers & Utilities
- 49.9 cm
- 35.9 cm
- 14.4 cm
- 7.7 kg
- Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 6 months / 1000 hours
- Sound Emission
- 31 dB
- Sound Emission (Economic Mode)
- 28 dB
