Military Class 4 is the next step in high quality components. The Dark Choke and Solid CAP will make sure that your PC runs more stable under extreme gaming conditions.
Dark Choke uses the special core design and allows the Dark Choke to run at a lower temperature with higher capacity and better power efficiency and stability.
With their aluminum core design and Japanese made quality, Solid CAPs are made for high-end design motherboard. Not only do Solid CAPs could provide lower Equivalent Series Resistance (ESR), but also work firmly for over-10-year.
Military class 4
Military Class 4 is the next step in high quality components. The Dark Choke and Solid CAP will make sure that your PC runs more stable under extreme gaming conditions. -
Dark choke
Dark Choke uses the special core design and allows the Dark Choke to run at a lower temperature with higher capacity and better power efficiency and stability. -
Solid CAP
With their aluminum core design and Japanese made quality, Solid CAPs are made for high-end design motherboard. Not only do Solid CAPs could provide lower Equivalent Series Resistance (ESR), but also work firmly for over-10-year. -
Humidity protection
The Gen 4 Fabric PCB helps to against moisture cause by some humid conditions and environments. -
EMI protection
The optimized EMI-proof design helps to keep users safe when during a long-time computer operation. -
ESD protection
Anti-ESD ICs and fuses onboard helps to totally protect your motherboard from electrostatic damage. -
High temperature protection
Certificated Military Class 4 components help to work stable under some extreme conditions. -
Isolated audio PCB
With traditional onboard audio the signal is distorted by electromagnetic signals from the rest of the PCB. Acting like a dedicated soundcard by physically isolating the audio circuitry which is separated by a isolating path. Less interference gives you a more clear audio signal. -
High quality audio capacitors
With the use of professional Nichicon Japanese capacitors, specially designed for audio purposes, H81M PRO-VD delivers high fidelity crystal clear sound with exceptional acoustics and realism. -
OC Genie 4
With the one-second overclocking option OC Genie we're giving you even more performance. Just hit the button and your PC gets another adrenalin shot straight away. Give your system an awesome performance boost with ease. -
M-Flash
Compared to common motherboards which need extra BIOS chips, MSI's M-Flash has a double advantage which doesn't need extra components and secondly, all your BIOS data will be saved in the USB drive. The stored data does not only have backup and upgrade function, moreover, it can also be seen as a portable BIOS chip which is actually able to boot up your PC.
- MSI H81M PRO-VD - motherboard - micro ATX - LGA1150 Socket - H81
- Product Type
- Motherboard - micro ATX
- Chipset Type
- Intel H81
- Processor Socket
- 1 x LGA1150 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 16 GB
- RAM Supported
- 2 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 2 x SATA-600, 2 x SATA-300
- USB / FireWire Ports
- 2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- Product Type
- Chipset Type
- Intel H81
- Processor Socket
- LGA1150 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 16 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111G
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 2.0 x16 , 2 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices , SATA-300 -connectors: 2 x 7pin Serial ATA - 2 devices
- 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x USB 3.0 , 1 x DVI-D , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x VGA
- Internal Interfaces
- 4 x USB 2.0 - header , 1 x audio - header , 2 x USB 3.0 - header , 1 x serial - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Features
- DMI support, M-Flash, MSI ClickBIOS 4
- Hardware Features
- Intel Smart Connect Technology, MSI Military Class IV, Military Class Essentials, OC Genie 4, MSI Fast Boot, Clear CMOS Button
- Software Included
- MSI Command Center, MSI Live Update 6
- Plug and Play
- 23.1 cm
- 17.3 cm
