MSI GeForce GTX 950 OC 2GB GDDR5 PCIe3.0 DX12 Graphics Card
Quicklinx: BL9FWS00 Mfr#: GTX 950 2GD5 OC
PLAY THE FUTURE - GeForce® GTX™ 950
The GeForce GTX 950 is a true gaming GPU designed for every PC gamer. It’s built to the exacting specifications of the GeForce GTX family and powered by NVIDIA Maxwell™—the most advanced GPU architecture ever created—to deliver 3x the performance of previous-generation cards.
The GeForce GTX 950 transforms your PC into a gaming rig to rival any game console. Enjoy fast and responsive MOBA gaming and the latest games in 1080p. Plus, it delivers a more interactive and cinematic experience with advanced visual effects driven by NVIDIA GameWorks™ and advanced DirectX 12.
FULL HD PERFORMANCE
Maxwell’s exceptional performance and efficiency means you can transform your basic PC into a modern gaming rig that can play the latest games at 1080p.
STEP ABOVE A CONSOLE
More powerful than any console, this card delivers a truly interactive, cinematic experience in the latest games with advanced effects driven by NVIDIA GameWorks™ and DirectX™ 12.
GET THE EDGE FOR MOBA
Competitive gamers demand instant responsiveness and low latency. The GeForce GTX 950 is designed from the ground up for the MOBA gamer, giving you the power and performance to rule the game.
NEW WAYS TO PLAY
GeForce Experience™ makes it easy to share your gameplay or co-play online with friends. With GeForce GTX, stream PC games to your NVIDIA® SHIELD™ devices using NVIDIA GameStream™.
Ready to get real about gaming? Experience the performance of the new GeForce GTX 950.
  • GPU Boost 2.0 technology
    Ensures the GPU runs at its peak performance and games at their highest frame rate possible. Offer new levels of customization including GPU temperature target, overclocking, and unlocked voltage.
  • 3D vision surround
    Support for NVIDIA 3D Vision, bringing a fully immersive stereoscopic 3D experience to the PC.
  • Military Class 4 components
    Certified to MIL-STD-810G standards for top stability and quality. Built with Hi-c CAP and solid CAP components.
MSI GTX 950 2GD5 OC - graphics card - GF GTX 950 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 950
2 GB GDDR5
Core Clock
1076 MHz
Boost Clock
1253 MHz
Effective Memory Clock
6.61 GHz
RAMDAC
400 MHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI: 2560 x 1600 / DisplayPort: 4096 x 2160 / HDMI: 4096 x 2160
Max Monitors Supported
4
Interfaces Details
DVI-I (dual link) , DisplayPort , HDMI , DVI-D (dual link)
API Supported
DirectX 12, OpenGL 4.5
3.7 cm x 17 cm x 11.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1076 MHz
Boost Clock
1253 MHz
RAMDAC
400 MHz
Max Resolution
4096 x 2160 at 60 Hz
4
Interfaces Details
API Supported
MSI Solid Capacitor, Nvidia 3D Vision Surround Ready, Nvidia 2-way SLI ready, MSI Afterburner, NVIDIA GPU Boost 2.0, Military Class 4 Components, Hi-C CAP, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.61 GHz
Bus Width
128-bit
Required Power Supply
350 W
Additional Requirements
6 pin PCI Express power connector
90 Watt
Software Included
Adobe Acrobat Reader, MSI Live Update Series, Microsoft DirectX, MSI Afterburner, display drivers, Norton Internet Security (60 days trial)
MIL-STD 810G
3.7 cm
17 cm
11.1 cm
439 g
