MSI GeForce GTX 1070 Aero 8G OC 8GB GDDR5 Graphics Card
Quicklinx: C5NBWS00 Mfr#: GTX 1070 AERO 8G OC
MSI GeForce GTX 1070 AERO 8G OC
THE ULTIMATE PC GAMING PLATFORM
Get Game Ready with GeForce® GTX.
GeForce GTX graphics cards are the most advanced ever created. Discover unprecedented performance, power efficiency, and next-generation gaming experiences.
THE ULTIMATE GRAPHICS FOR VIRTUAL REALITY
NVIDIA’s unique set of features ensure you get the right level of performance, image quality, and latency to ensure your VR experience is nothing short of amazing
A BETTER GAMING EXPERIENCE
The easiest way to update your drivers, optimize your games, and share your victories
STUTTER, TEAR-FREE GAMEPLAY
Synchronizes the display refresh to your GeForce GTX GPU for the fast, smooth gaming
Core/Memory
Boost Clock / Base Clock
721 MHz / 1531 MHz
8192 MB GDDR5 / 8008 MHz Memory
Video Output Function
DisplayPort x 3
HDMI x 1
Dual-link DVI-D x 1
Virtual Reality Ready
DirectX 12 Ready
Great for 4K
Gamestream to NVIDIA SHIELD
  • Amazing design
    MSI AERO graphics cards are equipped with a great design, crafted from high-quality materials. The sleek looks will fit great in almost any build.
  • The great graphics for virtual reality
    NVIDIA's set of features ensure you get the right level of performance, image quality, and latency to ensure your VR experience is nothing short of amazing.
  • Stutter, tear-free gameplay
    Synchronizes the display refresh to your GeForce GTX GPU for the fast, smooth gaming.
  • High-quality components
    These components are durable enough to withstand the torturous circumstances of extreme gaming and overclocking for extended usage.
  • Prepare for VR with MSI
    To experience and enjoy the impressive world of virtual reality, high-performance hardware is required. MSI provides the right advice to make sure your system is VR ready. MSI brings gamers an extremely realistic VR experience where games come alive.
  • MSI Afterburner
    MSI Afterburner is the widely used graphics card overclocking utility which gives you full control of your graphics cards. It also provides an incredibly detailed overview of your hardware and comes with some additional features such as customizing fan profiles, benchmarking and video recording.
MSI GTX 1070 AERO 8G OC - graphics card - GF GTX 1070 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1070
8 GB GDDR5
Core Clock
1531 MHz
Boost Clock
1721 MHz
Effective Memory Clock
8.008 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
3.5 cm x 26.9 cm x 11.1 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1531 MHz
Boost Clock
1721 MHz
VR Ready
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
Nvidia SLI Multi-GPU Technology, MSI Solid Capacitor, Nvidia 2-way SLI ready, MSI Afterburner, Military Class 4 Components, NVIDIA G-Sync ready, Nvidia SHIELD ready, Nvidia GeForce GTX VR Ready, HDCP
Size
8 GB
GDDR5 SDRAM
Effective Clock Speed
8.008 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
8 pin PCI Express power connector
150 Watt
Software Included
MSI Afterburner
MIL-STD 810G
3.5 cm
26.9 cm
11.1 cm
840 g
Limited warranty - parts and labour - 3 years
