MSI B150M PRO-VDH Intel S1151 DDR4 USB3.0 PCIe SATA3 uATX
Quicklinx: BQKSWS00 Mfr#: B150M PRO-VDH
With traditional memory design the memory signals are often distorted by electromagnetic signals from other components, making the system perform slower or become unstable. MSI introduces DDR4 Boost technology with optimized traces and fully isolated memory circuitry. This design ensures the memory signals stay pure for optimal performance and stability.
  • Unmatched memory performance and stability
  • Fast storage with sata express
    SATA Express offers a solution in high speed storage through PCI-Express, providing more bandwidth for the latest generation SSDs up to 16 Gb/s.
  • Dark Choke
    Dark Choke uses the special core design and allows the Dark Choke to run at a lower temperature with higher capacity and better power efficiency and stability.
  • Humidity protection
    Reduction in moisture absorption helps prevent "Conductive Anodic Filament". Untreated PCB's can have 10x higher failure rate.
  • High temperature protection
    All key components used in MSI motherboards have all passed military testing ensuring stable operation in the harshest environments.
  • Circuit protection
    Carefully selected materials, multiple PCB layers and shielding result in the best circuit protection for MSI motherboards.
  • ESD protection
    Each and every I/O port is protected against the hazards of Electro Static Discharge.
  • EMI protection
    All MSI motherboards comply with strict American FCC regulations and reduce the impact of Electromagnetic Interference.
  • Easy diagnostic
    MSI EZ Debug LED is an easy troubleshooting tool using 3 LEDs to indicate CPU / Memory / VGA operation every time you boot up your system. Run into trouble? Use the LEDs to easily identify the source of your problem and get back into operation quickly.
  • Enhanced CPU overvoltage protection
    Onboard overvoltage protection prevents overvoltage and short-circuit damage of the CPU and other components. A red LED near the 24 pin CPU power connector let you know that overvoltage protection is activated for easier troubleshooting.
  • VGA armor: reinforced PCI express slot
    With the increased size and weight of modern high end graphics cards, traditional PCI Express slots often show signs of bending or even breaking. Meet VGA Armor, strengthened PCI Express slots using more solder points to make sure you never have to worry about breaking off any of the slots.
  • Total fan control
    Total Fan Control gives you complete control of all your fans connected to the motherboard, through a revolutionary and easy to use interface.
  • Studio grade sound with Audio Boost
    With Audio Boost B150M PRO-VDH delivers high sound quality through the use of premium quality audio components. That way, you can enjoy breathtaking, crystal clear sound and music through 6-channel Audio or high impendence headphones and truly dominate the game.
  • Isolated audio PCB
    Audio Boost acts like a dedicated soundcard by physically isolating the audio circuitry to give you a more clear audio signal.
  • Chemi-con audio capacitors
    Delivering high fidelity crystal clear sound with exceptional acoustics and realism.
  • Separated left/right audio layers
    Equal and perfect sound quality for left & right channel audio through the use of seperated layers in the PCB.
  • Anti-popcorn noise
    Audio Boost protects your ears against annoying loud popping sounds when you plug devices in or out or turn your PC on/off.
  • Front dedicated headphone out
    Convenient use of the front panel audio output while retaining high quality amplified sound.
MSI B150M PRO-VDH - motherboard - micro ATX - LGA1151 Socket - B150
Motherboard - micro ATX
Chipset Type
Intel B150
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, ECC, unbuffered
Storage Ports
6 x SATA-600, 1 x SATA Express port
USB / FireWire Ports
4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (2 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel B150
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz
Supported RAM Integrity Check
ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x1
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 6 x 7pin SATA, 1 x SATA Express port
1 x DVI-D , 2 x USB 2.0 , 1 x VGA , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 keyboard , 4 x USB 3.1 Gen 1 , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet)
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
UEFI BIOS, MSI ClickBIOS 5
Hardware Features
Intel Extreme Memory Profile (XMP) support, Intel Small Business Advantage support, MSI Military Class IV, 4K Ultra HD ready, MSI Audio Boost, MSI Guard-Pro, Debug LED, MSI VGA Armor, overvoltage protection
Software Included
MSI M-Cloud
23.5 cm
22.8 cm
