Motorola LS1203 SCANNER
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: 7FH0WS00 Mfr#: LS1203-7AZU0100SR
Excellent value for everyday use
The Symbol LS1203 handheld scanner from Motorola delivers high quality laser scanning, user-friendly ergonomics and durability at an affordable price. Designed to meet the needs of small businesses, the Symbol LS1203 provides the performance and features needed to significantly reduce data entry errors and boost productivity day in and day out in gift shops, boutiques, sporting goods, jewellers, video stores, florists and other small local retailers. Easy and comfortable to use, this high-value cost-effective scanner offers the reliability and investment protection that have made Motorola the global leader in handheld bar code scanning.
Increased productivity from the start
For point of sale check-out applications, the Symbol LS1203 provides the power to improve operational efficiencies right out of the box. The plug-and-play design virtually eliminates installation hassles. The intuitive ergonomic design eliminates training requirements -- employees are up and running in minutes. Manual keying is eliminated, reducing cashier errors and ensuring that your customers are charged the correct amount. The result is faster checkout, increased customer satisfaction and a quick return on investment. In the back room, the Symbol LS1203 automates paper-based processes, such as inventory management, translating into more accurate information and less time spent on day-to-day administrative tasks -- and more time spent serving customers.
Durable construction combined with future-proofing With a single board construction and durable scan element, the Symbol LS1203 can easily stand up to daily use and those inevitable drops. With everyday operation you can count on, the Symbol LS1203 ensures minimal maintenance costs and maximum uptime. And integrated multiple interfaces provide the investment protection you need to ensure that the scanner you buy today will work with tomorrow's POS system.
FEATURES
  • Durable construction: single board construction; meets Motorola's stringent 5 ft. drop tests. Designed for continuous usage all day, every day; significantly reduces downtime and repair costs
  • Multiple interfaces: RS232, USB, KBW (keyboard wedge) in one scanner. Simplifies installation and integration; futureproof solution ensures compatibility with your host/POS today and tomorrow
  • Ergonomic hybrid design featuring sleek, lightweight, balanced form factor. Maximum comfort for all day use; reduces user fatigue
Barcode scanner
Handheld
USB
Compatibility
PC
Dimensions & Weight / Depth
18 cm
Dimensions & Weight / Height
6.2 cm
Dimensions & Weight / Weight
122 g
Dimensions & Weight / Width
6 cm
