Your basket is empty
Monster PowerCenter HTS 950/Clean Power - 8 outlets
Quicklinx: 54FKWS00 Mfr#: 121537
A Fact: Dirty AC Power Can Ruin Your Home Theater Picture & Sound
The power coming through AC power outlets is full of interference and line disturbances that cause hum, buzz, and static, degrading your home theatre audio and video performance. In addition, electronic appliances, cell phones, and even home theatre components themselves all generate electronic noise that further affects your home theatre sound and picture. The detrimental effects of AC power cannot be removed by ordinary surge protectors.
The HTS 950 Features Patented Clean Power Stage 1, for Better Picture & Sound
Monster Clean Power Circuitry Stage 1 filters provide excellent AC power line noise rejection in addition to isolating audio and video equipment to reject component-generated noise. When you connect your home theater components to a Monster HTS 950 PowerCenter you get the best possible picture and sound with more natural audio, increased dynamic range, and the most vivid video images possible.
The Monster Power HTS 950 Excels in Safety and Protection
Sensitive electronics in your home theater components can be easily damaged from the surges, dips and spikes common with AC power today. The problem is even worse if you live in an area plagued by lightning or power blackouts. Extremely high voltages can travel through the power line, seriously damaging or even destroying your components. The Monster HTS 950 features a high surge absorption capacity of over 5508 Joules for excellent protection. Unlike ordinary surge protectors, advanced Monster PowerCenters also actively monitor incoming power and automatically disconnect your valuable equipment before can damage occur.
Patent Pending Tri-Mode Protection Circuitry for the Ultimate Surge Protection Safety
The HTS 950 provides advanced power protection that goes far beyond competing surge protectors with patented Tri-Mode disconnect circuitry. Unlike ordinary surge protectors which only use MOVs (Metal Oxide Varistors) to absorb surges, the HTS 950's Tri-Mode Protection circuitry automatically disconnects all of your connected AV equipment, completely isolating your valuable AV components from dangerous power conditions. Ordinary surge protectors leave equipment connected to AC power and vulnerable to damage. Tri-Mode also sounds an audible alarm, letting you know your system has been protected.
Complete Protection for All Your Home Theatre Connections
All of a component inputs and sockets need to be protected, or the entire system will be vulnerable. Often missed are telephone lines, IPTV, and cable and satellite connections, which can carry dangerous power surges and spikes to your equipment. The Monster HTS 950 features comprehensive protection with coaxial, PAL, Ethernet, and phone connections for complete satellite, IPTV, cable, and HDTV protection.
Convenient Hook Up and More!
The HTS 950 provides colour-coded sockets that are specially labeled for home theatre. Also included are corresponding color-coded stickers for your components' power cords. This patent-pending system saves you a lot of aggravation by helping you not accidentally unplug the wrong component (and wipe out its programming!) You'll also appreciate the heavy-duty extra-long power cord, and 24k gold contact FlatProfile plug lets you keep furniture flat against the wall. You get more of everything from Monster PowerCenters!
Monster Cable Products
Product Line
Monster Home Theater PowerCenter
HTS950 with Clean Power Stage 1
Power Output Connectors
