Be comfortable while on the go with this compact, mobile mouse. Smooth optical performance, a scroll wheel and four buttons keep you productive. Then simply snap in the receiver to automatically turn off the mouse, saving battery life.
Comfort
Designed by ergonomic experts for comfort in either hand, with rubber grips featured on each side of the mouse. -
Snap-in receiver
Use the snap-in receiver to turn off the mouse and extend battery life. -
4 buttons
Use the back button to easily navigate folders or web pages, and press the scroll wheel for AutoScroll. -
Battery status indicator
Red light indicates when your battery is running low. -
High definition optical technology
This makes it more responsive, more precise, smoother tracking. -
Designed for notebook PCs
Compact and comfortable, our handy notebook and laptop products are designed for convenience and mobility. -
6+ months battery life
Work with less interruption with longer battery life. -
Wireless technology
Give yourself room to move - wireless mouse products let you work without worrying about tangled wires.
- Microsoft Wireless Mobile Mouse 3000 - mouse - RF - black
- Mouse
- Connectivity Technology
- Wireless - RF
- Black
- Orientation
- Right and left-handed
- 5.6 cm x 9.5 cm
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Scrolling wheel, rubber side grips, High Definition Optical Technology, battery indicator, Magnifier
- Battery
- 1 x AA type
- OS Required
- Microsoft Windows Vista / XP / 7, Apple MacOS X 10.2 - 10.5
- Microsoft Certification
- Compatible with Windows 7
- Mouse
- Wireless Receiver
- Orientation
- 5.6 cm
- 9.5 cm
- Black
Input Device
- Wireless
- Interface
- RF
- Optical
- Buttons Qty
- 3
- 1000 dpi
- 1 x USB - 4 pin USB Type A
- AA type
- Technology
- Alkaline
- Installed Qty
- 1
- Run Time (Up To)
- 6 months
- OS Required
- System Requirements Details
- MacOS X 10.2.x - 10.5.x HD 30 MB , Windows XP/Vista/7 HD 100 MB
