Microsoft Wireless Mobile Mouse 1850 for Business
Quicklinx: CSTHWS00 Mfr#: 7MM-00002
Designed for Comfort and Portability
The Wireless Mobile Mouse 1850 is designed for life on the go, offering wireless freedom and built-in transceiver storage for ultimate mobility. Comfortable to use with either hand and a scroll wheel for easy navigation makes this mouse the ideal device for your modern, mobile lifestyle.
  • Scroll wheel
    Move through documents and webpages quickly.
  • Comfort and portability
    Compact design to fit in your hand and go wherever you go.
  • Plug-and-Go nano transceiver
    Leave the nano transceiver plugged in when you're on the go, or stow it in the mouse.
  • Comfortable in either hand
    Use your mouse with your left or right hand. Ambidextrous design makes it comfortable either way.
Microsoft Wireless Mobile Mouse 1850 for Business - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right and left-handed
5.81 cm x 10 cm x 3.82 cm
90 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Performance
3000 fps, up to 20 inches per second, 1000 points per inch
Scrolling wheel, Nano wireless receiver
AA type
Apple MacOS X 10.x, Microsoft Windows 7, Windows 8, Windows 8.1, Windows RT
Mouse
Wireless Receiver
Orientation
5.81 cm
10 cm
3.82 cm
90 g
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 5 m
Optical
Buttons Qty
3
Performance
1 x USB - 4 pin USB Type A
VCCI, BSMI, ISO 9001, GOST, ISO 14001, CB, RSS-210, MIC, FCC, R&TTE, NTRA, KCC, WEEE, ANATEL, TELEC, URSEC, REACH, UkrSEPRO, China EIP, CITC, RATEL, NCC, iDA; USB 2.0
AA type
Alkaline
Run Time (Up To)
6 months
5 - 80% (non-condensing)
