Compact comfort meets convenient mobility. This compact wireless mouse has everything you need to stay connected while you're on the go.
Nano transceiver
Leave plugged in when you're on the go or stow in mouse. -
Quality performance
Quality performance with 1000 dpi and 2.4 GHz wireless. -
On/off switch
Conserve more battery power by turning your mouse off when not in use. -
Designed for comfort
Created for either hand and includes 3 buttons and a scroll wheel.
- Microsoft Wireless Mobile Mouse 1000 for Business - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- Orientation
- Right and left-handed
- Localisation
- EMEA
- Wireless Receiver
- USB wireless receiver
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Scrolling wheel, on/off power switch
- Battery
- 1 x AA type
- OS Required
- Apple MacOS X 10.4.x - 10.6.x, Microsoft Windows Vista / XP / 7
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- Mouse
- Wireless Receiver
- Orientation
- Black
- Localisation
- EMEA
Input Device
- Wireless
- Interface
- 2.4 GHz
- Buttons Qty
- 3
- 1000 dpi
- 1 x USB - 4 pin USB Type A
- AA type
- Technology
- Alkaline
- Installed Qty
- 1
- Run Time (Up To)
- 10 months
- OS Required
- Additional Requirements
- USB port
- Limited warranty - 2 years
