The Wired Desktop 400 combines a spill-resistant keyboard and optical mouse to deliver all the features you need - and more - with Microsoft quality and reliability. Enjoy plug-and-play setup, quiet-touch keys, and a comfortable ambidextrous mouse. Use your mouse with your left or right hand - ambidextrous design makes it comfortable either way. A high-resolution optical sensor delivers greater accuracy and control.
Quiet-touch keys
Quiet, responsive, thin-profile keys. -
Spill-resistant design
Integrated water channels drain the liquid away. -
Windows start button
Simply press to launch your Start menu. -
Plug-and-play
No software is needed. Just connect the keyboard to your PC and go! -
Comfort for either hand
Use your mouse with your left or right hand - ambidextrous design makes it comfortable either way. -
Optical technology
A high-resolution optical sensor delivers greater accuracy and control. -
Scroll wheel
For faster on-screen navigation.
- Microsoft Wired Desktop 400 for Business - keyboard and mouse set - UK
- Keyboard and mouse set
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Spillproof
- Pointing Device
- Mouse - optical
- Scrolling wheel, 400 dpi resolution, right and left-handed
- 3-year warranty
- Interface
- USB
Input Device
- UK
- Spillproof
Pointing Device
- Mouse
- Movement Detection Technology
- Optical
- Pointing Device Features
- Plug and Play
- OS Required
- Apple MacOS X 10.2, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista
- Limited warranty - 3 years
