Windows 10 is so familiar and easy to use, you'll feel like an expert. The Start Menu is back in an expanded form, plus your pinned apps and favorites are brought over so they're ready and waiting for you.
It starts up and resumes fast, has more built-in security to help keep you safe, and is designed to work with software and hardware you already have.
The web that works the way you do
Windows 10 comes with Microsoft Edge, a browser that's built to give you a better web experience. Write or type notes directly on webpages and share them with others, read online articles free of distraction, and save your favorite reads for later access. -
Multi-doing helps you get to "done" faster
Easily snap up to four apps in place and see all open tasks in a single view. You can even create virtual desktops when you need more space or want to group things by project. -
Interact with your device however you want
Touch, type, write: the choice is yours so you can use whatever works best for what you're doing. -
Flexibility to work how you want
Windows 10 enables your apps to look and work great in all modes, on all devices. On 2-in-1 devices, your screen can be optimized to work with touch or keyboard and mouse.
- Windows 10 Home - box pack - 1 licence
- Operating System
- Windows 10 Home - 32/64-bit
- Product Type
- Box pack
- Licence Type
- 1 licence
- Language
- English International
- Media
- Flash drive
- Operating System
- Product Type
- Box pack
- Media
- Flash drive
- Language
Licencing
- Licence Type
- 1 licence
- Min Processor Type
- 1 GHz
- Min RAM Size
- 1 GB
- Min Hard Drive Space
- 16 GB
- Additional Requirements
- USB port, DirectX 9.0 compatible graphics card, 800 x 600 monitor resolution
