Visual Studio Ultimate 2012 is the state-of-the-art development solution that empowers teams of all sizes to design and create compelling applications to delight users. You can use flexible agile planning tools - like capacity planning, taskboards, and backlog management - to enable incremental development techniques and agile methodologies, at your own pace. Use advanced modeling, discovery, and architecture tools to describe your system and help ensure that your architecture vision is preserved in the implementation. Bring development and operation teams together by using IntelliTrace in production, Operations Manager Connector, and Preemptive Analytics. Improve quality and reduce time to resolution by generating actionable bugs from deployed software, and effectively partner with the operations staff to provide data that gives developers greater insight into production issues.
Eliminate 'no repro' with IntelliTrace
The IntelliTrace feature makes the "no-repro" discussion a thing of the past. Testers can file rich and actionable bugs with system information, and even include an environment snapshot. That way developers can reproduce the reported bug in the state it was found. -
Understand existing architecture
The architecture explorer helps you understand and unleash the value of your existing code assets and their inter-dependencies. You can produce detailed models of exactly how an application is constructed and even drill-down into specific areas for a deeper understanding. -
Ensure architectural compliance
Use the layer diagram to define and communicate logical application architecture and to validate code artifacts against the required architecture. Layer diagrams help your development efforts stay on track so your application conforms to your original vision. -
Be proactive about agile project management
Visual Studio Ultimate is optimized for today's iterative development process with features that help you remain productive and react to potential risks before they happen. You can monitor the health of your project using reports that are automatically generated. Plus manage your project's capacity with historical data and Microsoft Excel-based planning documents.
- Microsoft Visual Studio Ultimate 2012 with MSDN - box pack - 1 user
- Product Type
- Box pack
- Category
- Development tools - RAD suites
- Licence Qty
- 1 user
- Platform
- Windows
- Language
- English
- Distribution Media
- DVD-ROM
- Category
- Product Type
- Box pack
- Platform
- Windows
- DVD-ROM
- Language
- English
Licencing
- Licence Type
- 1 user
- Supported OS
- Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits)
- Hardware Requirements
- Microsoft Windows - 1.6 GHz - RAM 1 GB - HD 10 GB
- Additional Requirements
- DirectX 9.0 compatible graphics card, 5400 RPM or faster hard drive, 1024 x 768 monitor resolution
