Microsoft PowerPoint 2013 has a better look: It's cleaner and primed for use on tablets and phones, so you can swipe and tap your way through presentations. Presenter View automatically adapts to your projection set-up, and you can even use it on a single monitor. Themes now come with variations, which make it simpler to hone in on the look you want. And when you're working with others, you can add comments to ask questions and get feedback.
Start screen
The start experience helps you jump-start the creative process with a collection of new themes. -
Theme variants
Choose from alternative color schemes and then apply the look you like with a single click. -
Alignment guides
Exhibit a designer's touch by aligning shapes, text boxes, and other graphics with text. -
Merge shapes
Use the Union, Combine, Fragment, Intersect, and Subtract tools to merge two or more shapes into the shape you want. -
Slide zoom
Direct your audience's attention to your main point. Zoom in on a diagram, chart, or graphic with a couple of clicks, and then zoom out just as smoothly. -
Navigation grid
Easily switch slides - in or out of sequence - from a grid that only you see, your audience sees only what you've selected. -
Auto-extend
When you project to a second screen, the settings ensure that your presentation appears on the correct screen. -
Reply comment
Place and track comments next to the text you're discussing so everyone can readily see who replied to whom, and when. -
Simplified sharing
Your presentations are saved online to SkyDrive or SharePoint by default. Send everyone a single link to the same file, along with their viewing and editing permissions, and be assured that everyone sees the latest version. -
PowerPoint web app coauthoring
You and your team can work together on the same presentation at the same time from the desktop or in the browser with the PowerPoint Web App.
- Microsoft PowerPoint 2013 - box pack - 1 PC
- Product Type
- Box pack
- Category
- Office applications - presentation
- Licence Qty
- 1 PC
- Licensing Details
- 32/64-bit, medialess
- Platform
- Windows
- Language
- English
- Category
- Product Type
- Box pack
- Platform
- Windows
- Language
- English
Licencing
- Licence Qty
- 1 PC
- Details
- Supported OS
- Microsoft Windows 7, Windows 8, Microsoft Windows Server 2008 R2 64-bit Edition (except RDS mode), Microsoft Windows Server 2012 64-bit Edition (except RDS mode)
- Hardware Requirements
- Microsoft Windows (32 bit) - Intel x86-64 - 1 GHz - RAM 1 GB - HD 3.5 GB , Microsoft Windows (64 bit) - Intel x86-64 - 1 GHz - RAM 2 GB - HD 3.5 GB
- Additional Requirements
- DirectX 10.0 compatible graphics card, 1024 x 576 monitor resolution, Microsoft .NET Framework 3.5 or later
