Comfortable in either hand
Rubber side grips and a contoured shape for either hand. -
BlueTrack technology
Take advantage of BlueTrack technology, which combines the power of optical with the precision of laser for remarkable tracking on virtually any surface. -
Wired reliability
Designed for trouble-free performance, eliminating the worry of battery life. -
Three customizable buttons
Give yourself some shortcuts. -
Savings
Reduce costs with volume pricing.
- Microsoft Comfort Mouse 3000 for Business - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- Orientation
- Right and left-handed
- 6.6 cm x 11.5 cm x 4.1 cm
- 92 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Performance
- 8000 fps, 28 G maximum acceleration
- Programmable buttons, scrolling wheel, Microsoft BlueTrack Technology
- Cables Included
- 1 x USB cable - integrated - 2 m
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.4.x - 10.6.x
- 3-year warranty
- Mouse
- Orientation
- 6.6 cm
- 11.5 cm
- 4.1 cm
- 92 g
- Black
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- Performance
- 1 x USB - 4 pin USB Type A
- Cables Included
- UL, VCCI, BSMI, ISO 9001, GOST, cUL, ICES-003, ISO 14001, CB, EMC, FCC, KCC, WEEE, ACA, REACH
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 80% (non-condensing)
