High Fidelity multimedia system - 2.1 subwoofer speakers for full range sound
2.1 speaker system with subwoofer for quality sound production.
Clear sound and Hi-Fi 2.1 subwoofer system designed for multimedia and computer applications.
Bass reflex tunnel for depth and deeper bass effect. Tower satellites with minimum distortion and clearer sound. Comes with front master volume knob for easy adjustment.
Technical Specifications:
Amplifier:
Output power: 40 Watt RMS
Power distribution: 12 Watt x 2 + 16 Watt
Harmonic distortion: < 0.3% 1 W 1 kHz
Frequency response: 35 Hz - 20 kHz
Signal/Noise ratio: > 75 dB
Separation: > 45 dB
Input sensitivity: Satellites - 500 mV, Subwoofer - 130 mV
Speakers:
Tweeter driver type: 2.5" x 2
Tweeter rated power: 15 Watt x 2 6 ohm
Subwoofer driver type: 5"
Subwoofer rated power: 20 Watt 4 ohm
Interfaces:
Output: RCA
Input: RCA
Power:
AC power: AC 220 - 240 V, 50 Hz 140 mA or 120 V, 60 Hz 280 mA
Package Contents:
M-700 subwoofer
M-700 satellites x 2
3.5 mm stereo to 2RCA cable
User manual
Dimensions:
Subwoofer: 165 x 290 x 240 mm
Satellites: 90 x 75 x 180 mm
Product net weight: 4.1 kg
Giftbox dimension: 343 x 358 x 208 mm
Giftbox Net weight: 16.4 kg
Export carton box dimension: 431 x 736 x 355 mm
Export carton gross weight: 20 kg
