Designed with a beautiful leather finish, these versatile speakers fit perfectly with your living room, computer room or even your bedroom. Bass reflex tunnel design means deeper bass effects and the classic bookshelf stereo speaker style creates better dynamic sound for a realistic effect.
Ideal for digital movies, TV. PC / laptops, CD / DVD and multimedia application.
Comes with two connection methods - wireless Bluetooth music transfer and traditional audio connection.
- Wireless Bluetooth music entertainment; playback from any Bluetooth device
- Bookshelf stereo speakers for all room types
- Bluetooth AVRCP and A2DP profiles supported
- Powerful and clear sound
- Treble and bass effects: full range sound spectrum
- Support any digital media player with 3.5mm stereo connection
Package contents
- H21 speakers x 2 pcs
- Speaker interconnect cable, 3 m
- AC power adapter
- 3.5mm stereo to 2RCA cable, 1.8 m
- User manual
- Microlab 2.0 speaker set Bluetooth White Leather
- Product Type
- Bookshelf Speaker
- Right - 116 x 198 x 202 mm, Left - 116 x 189 x 202 mm
- 4.7 kg
- Connectivity Interfaces
- Bluetooth, 2RCA
- Output
- 36 Watts
Amplifier
- Output power:
- 36 Watt
- Distribution:
- 18 Watt x 2 RMS
- Harmonic distortion:
- < 0.5 % 1 Watt 1kHz
- Frequency range:
- 50 Hz - 20 kHz
- Signal/Noise ratio:
- > 70 dB
- Separation:
- > 60 dB
Speakers
- Tweeter drive unit:
- 1”
- Rated power:
- 10 Watt, 4 ohm
- Woofer drive unit:
- 3.5”
- Rated power:
- 20 Watt, 8 ohm
- Input:
- 2RCA
- Output:
- Terminal binding post
- Power supply:
- AC 100 V - 240 V, 50 / 60 Hz,
- Output:
- - DC 18 V / 2 A
Dimensions
- Product dimension:
- Right - 116 x 198 x 202 mm (W x H x D), Left - 116 x 189 x 202 mm (W x H x D)
- Net weight:
- 4.7 kg
- Giftbox dimension: 337 x 239 x 235 mm
- 337 x 239 x 235 mm
- Giftbox net weight:
- 5.1 kg
