Your basket is empty
Matrox Millennium P690 PCI 128MB DDR2 DualHead 2XDVI-I
Quicklinx: 7249WS00 Mfr#: P69-MDDP128F
The Matrox Millennium P690 PCI offers 128MB of graphics memory and full DualHead support for using two digital or analog monitors at high resolution and pristine image quality. With ultra-low power consumption, fanless cooling and unified display drivers for easy deployment across multiple systems, the P690 PCI is suitable for a wide range of professional applications. This graphics card builds upon the reliability, stability, and features of the proven Millennium P-Series product line, making it an ideal choice for use in long-life environments.
Matrox Millennium P690 PCI graphics card - MGA P690 - 128 MB
Graphics card
Bus Type
PCI
Graphics Engine
Matrox MGA P690
128 MB DDR2
Max Resolution
2048 x 1536
2 x DVI-I - 29 pin combined DVI , 2 x VGA - 15 pin HD D-Sub (HD-15) (with adapter)
16.8 cm x 10.7 cm
3 years warranty
Graphics card
Bus Type
PCI
Graphics Engine
Matrox MGA P690
Max Resolution
2048 x 1536
Size
128 MB
DDR2 SDRAM
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows Vista, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions)
2 x DVI-VGA adapter
Software Included
Matrox PowerDesk, Driver
CSA, VCCI, EMC, FCC, RoHS, WEEE
16.8 cm
10.7 cm
Limited warranty - 3 years
