Along with the reliability, stability, and features of the proven Millennium G550 product line, this card is designed for the PCI slots found in most modern PCs and has a low-profile form factor to fit in an even wider variety of systems. With support for using 2 monitors at a time this product is ideal for a variety of professional applications, including computer-aided dispatch, process control, and alarm monitoring. By helping to manage large amounts of information, Matrox multi-display technology can improve productivity and reduce errors.
Key features
Matrox DualHead to use 2 monitors at a time (in "independent" or "stretched" mode)
PCI card compatible with all PCI and PCI-X slots
Low-profile form factor to fit in a wider variety of systems
Passive cooling (heat sink with no fan) for silent operation and extra reliability
Unified Microsoft WHQL-certified drivers for Millennium G-Series products
Easy-to-use Matrox PowerDesk driver interface
Matrox Clone to view a copy of one display on the other display
Matrox Multi-Display Zoom to view a portion of one display full-screen on the other display
Matrox DVDMax to view hardware-accelerated video playback in a video window on one display and full-screen on the other display
Support for displays with special aspect ratios
Support for customizable unattended installation for rapid multi-system setup
Open-source Linux/Unix display drivers available
Global sales and technical support
3-year warranty
Hardware included
Matrox Millennium G550 Low-profile PCI graphics card (with factory-installed ATX bracket)
Separate low-profile bracket
Software included
Matrox display drivers for Microsoft Windows 2000 and Windows XP *
Matrox PowerDesk (driver interface and utilities)
- Matrox Millennium G550 Low-profile - graphics card - MGA G550 - 32 MB
- Graphics card - low profile
- Bus Type
- PCI / 66 MHz
- Graphics Engine
- Matrox MGA G550
- Memory
- 32 MB
- Max Resolution
- 2048 x 1536
- Max Monitors Supported
- 2
- 2 x DVI-I - 60 PIN LFH
- 16.8 cm x 6.4 cm
- Bus Type
- PCI / 66 MHz
- Graphics Engine
- Matrox MGA G550
- Max Resolution
- 2048 x 1536
- 2
- Size
- 32 MB
- OS Required
- Microsoft Windows 2000 / XP
- 16.8 cm
- 6.4 cm
Customer reviews
Write a review for the Matrox Millennium G550 32MB PCI Dual VGALow Profile OEM here!
Works in low profile Dell
Reviewed by Paul. Review Posted 29/11/2007
I'm not sure what the other reviewers' problems were. I bought this for my low profile Dell Optiplex 745. It came with a full size metal bracket fitted, but came with the low profile bracket. Undo the screws, replace bracket, do up screws. Installed into available PCI slot. Came with VGA (not DVI) splitter and installation CD. The socket on the back of the card is neither DVI or VGA but it fits into the splitter cable. No problems.
- Overall
- Ease of use
- Value for money
Matrox G550 Dual DVI
Reviewed by Anonymous Review Posted 18/07/2006
This product is described on the DABS page as PCI and PCI X compatable. It will not fit into the MSI K8N Neo4 PCI Express slot on my board and did not work when fitted to a normal PCI slot.My old G550 card is AGP and has never gone wrong after 4 years on the road and gets 10/10.
- Overall
- Ease of use
- Value for money
wrong size
Reviewed by Anonymous Review Posted 12/03/2007
This is claimed to be PCI compatible and does not fit into a HP 7600 small form PC. Why do manufacturers waste so much of other peoples time? They deserve to go out of business
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
