The Matrox M9140 LP PCIe x16 quad head graphics card renders pristine images across four monitors at resolutions up to 1920x1200 per output (digital or analog) for an exceptional multi-display user experience. With 512 MB of memory and advanced desktop management features such extending the Windows Taskbar to span multiple displays and support of independent or stretched modes, the M9140 drives business, industrial, and government applications with extraordinary performance. Its low-profile form factor makes it easy to integrate into a wide variety of systems, it offers optimal Windows Vista Aero support (WDDM mode), and it can be paired with another M9140 graphics card to support up to eight displays from a single system.
The M9140 graphics card builds upon the reliability and stability of previous Matrox products, and retains core Matrox benefits such as long life-cycles, top-to-bottom manufacturing and unified display driver models for easy deployment across multiple systems.
- Matrox M9140 - graphics card - M9140 - 512 MB
- Graphics card - low profile
- Bus Type
- PCI Express x16
- Graphics Engine
- Matrox M9140
- Memory
- 512 MB DDR2
- Max Resolution
- 1920 x 1200
- Max Monitors Supported
- 4
- 4 x DVI-I - 24+5 pin combined DVI (on supplied cable) , 4 x VGA - 15 pin HD D-Sub (HD-15) (with adapter)
- API Supported
- OpenGL 2.0
- 1.9 cm x 16.8 cm x 6.8 cm
- Microsoft Certification
- Windows 8 Compatible
- 3-year warranty
- Bus Type
- PCI Express x16
- Graphics Engine
- Matrox M9140
- Max Resolution
- 1920 x 1200
- 4
- API Supported
- OpenGL 2.0
- Size
- 512 MB
- Technology
- DDR2 SDRAM
- OS Required
- Linux, Microsoft Windows Server 2003, Microsoft Windows Vista (32/64 bits), Microsoft Windows Embedded Standard 7, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits)
- Additional Requirements
- CD-ROM
- Included Accessories
- Low-profile bracket
- Cables Included
- 1 x DVI cable , 4 x DVI-VGA adapter
- Software Included
- Drivers & Utilities, Matrox PowerDesk
- This product has been tested to meet all of the technical requirements to be Windows 8 Compatible.
- EMC, RoHS, WEEE
- 1.9 cm
- 16.8 cm
- 6.8 cm
- Limited warranty - 3 years
