Pump up the volume and enjoy! Wirelessly connect, stream music, manage phone calls and control volume. Take it on the road or relax and listen at home.
Rocking sound
Crystal clear sound. Pump up the volume and enjoy! -
Connect and play
Wirelessly connect, stream music, manage phone calls and control volume -
Take it anywhere
Perfect for life on the go. Take it on the road or relax and listen at home -
Design
In five bold colors, this unique design is sure to turn some heads -
5 hour Battery
Enjoy 5 hours of continuous play without recharging. Recharge the built-in lithium-ion battery with the convenience of the included micro-USB cable and rock on
- Logitech X100 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Continuous Power
- 3 Watt
- Amplifier
- Integrated
- Bluetooth
- Speaker System Details
- 1 x portable speaker 3 Watt
- Grey
- Power Options
- USB powered
- Battery
- Speaker battery rechargeable - Lithium Ion
- 9.6 cm
- 162 g
- Product Type
- Hands-Free Function
- Enclosure Colour
- Grey
Speaker System
- Speaker Type
- Active
- Continuous Power
- 3 Watt
- Amplifier
- Integrated
- Bluetooth
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP)
- Transmission Range
- 10 m
- Controls
- Power on/off, volume
- Speakers Included
- 1 x portable speaker - 3 Watt - wireless
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Mini-USB cable
- Power Source
- Battery
- Options
- USB powered
- Rechargeable - Lithium Ion
- Run Time (Up To)
- 5 hour(s)
- 9.6 cm
- 162 g
