Logitech Wireless Headset H600
Quicklinx: 81FCWS00 Mfr#: 981-000342
Cut loose from your PC with this lightweight, portable headset. The laser-tuned drivers and 10-meter range make it easy to listen and chat whether you're at your desk or on the couch.
  • WIRELESS AUDIO
    Insert the leave-in nano receiver into a USB port and move freely around home or office, up to 33 feet (10 m) away from your computer. Enjoy up to six hours of wireless audio with the rechargeable battery
  • RICH STEREO SOUND
    Laser-tuned drivers provide enhanced, digital audio for full immersion in music, games and calls
  • NOISE CANCELING MIC
    Flexible mic can be positioned for better voice capture and background noise reduction. Right-sided boom can be tucked inside the headband and out of the way when you're not using it
  • ON-EAR CONTROLS
    Power on and off, adjust the volume or mute your calls with simple on-ear controls located on the right ear cup. Store the nano-receiver along bottom of the left ear cup when you're on-the-go
  • PADDED COMFORT
    Adjustable padded headband with swivel-mounted foam ear cushions are ultra-comfortable even after hours of listening. Headset folds up easily for portability
  • USB RECEIVER
    Simply insert the nano-receiver into your computer USB port and forget about it- you're ready to talk, listen to music or game. Charge via the included USB cable; even talk while it's charging. Enjoy up to six hours of wireless audio with the rechargeable battery
Logitech Wireless Headset H600 - headset
Headset - 2.4 GHz - wireless
Recommended Use
Computer
Headphones Form Factor
On-ear binaural
Wireless
Wireless Technology
2.4 GHz radio frequency
Radio Frequency Range
2.4GHz
Sound Output Mode
Stereo
Microphone
Boom
Microsoft Certification
Compatible with Windows 7
Recommended Use
Computer
Max Operating Distance
10 m
Audio Output
On-ear binaural
Wireless
Wireless Technology
Sound Output Mode
Stereo
Microphone
Boom
Wireless Link
2.4GHz
Transmission Range
10 m
Connector Type
USB (4 PIN USB Type A)
Wireless adapter
Cable Details
USB charge cable
Headphone battery
Run Time (Up To)
6 hour(s)
