Logitech Stereo Headset H150 Coconut
Quicklinx: 8KHYWS00 Mfr#: 981-000350
Speak clearly with this simple, easy-to-use analog headset. With full stereo sound, your headset is great for voice and video calls. The noise-canceling microphone cuts background noise - and rotates out of the way when you're not using it. Just plug your headset into the 3.5 mm input and output jacks on your computer and it's ready to go. Simple as that!
  • ENJOY CRISP, CLEAR INTERNET CALLS AND MUSIC FROM YOUR PC
    Versatile and adjustable, for computers that utilize separate 3.5 mm microphone-in and audio-out ports. In-line controls let you control volume or mute calls without disruption. Convenient noise-cancelling microphone reduces background noise
  • Stereo sound
    Full stereo sound for crisp, clear voice and video calls, music, games and more. An essential stereo headset for either personal use or the office
  • Rotating microphone
    Boom can rotate 180° to be worn on the left or right. Flexible mic can be positioned for better voice capture and background noise reduction. Boom can be tucked out of the way when you're not using it
  • In-line controls
    Convenient in-line controls on the headset cord let you adjust the volume or mute calls without disruption
  • Adjustable headband
    Sturdy yet lightweight stereo headset has a broad range of adjustment. Ultra-soft foam ear cushions provide hours of comfort
  • Dual Plug Connection
    Connects to computers that utilize separate 3.5 mm audio jacks for microphone-in and audio-out ports. Not compatible with Chromebook , tablets or Mac
Logitech Stereo Headset H150 - headset
Headset - wired
Recommended Use
Computer
Coconut
Headphones Form Factor
On-ear binaural
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Microphone
Built-in - boom
Microphone Operation Mode
Mono
Headset - wired
Coconut
Recommended Use
Computer
Audio Output
On-ear binaural
Dynamic
Wired
Sound Output Mode
Stereo
In-Cord Volume Control
Microphone
Boom
Mono
Connector Type
Audio line-out (mini-phone stereo 3.5 mm) , Microphone (mini-phone 3.5mm)
Cable Details
Headset cable
