Buttons are easy to find by touch. And the smooth contours feel great in your hand. You'll be in control from the first slide to the last.
It'll be easy for your audience to see exactly what you're pointing to.
The 2.4 GHz wireless allows you to enjoy the freedom to move around the room and mingle with your audience for greater impact.
Lets you know how much power is available with just a glance.
There's no software to install. Just plug the receiver into a USB port to begin. And when the show is over, you can store the receiver in the presenter.
- Logitech Wireless Presenter R400 - presentation remote control
- Presentation remote control
- Connectivity Technology
- Radio
- Supported Devices
- Personal computer
- Max Operating Distance
- 15 m
- Battery
- Standard - AAA type
- Microsoft Certification
- Compatible with Windows 7
- 3 years warranty
Remote Control
- Radio
- Supported Devices
- Personal computer
- 15 m
- Battery level indicator, built-in laser pointer, LED indicator
- Operating System
- MS Windows XP, MS Windows 7, MS Windows Vista
- Included Accessories
- Carrying case, 2 AAA batteries, wireless receiver
- Battery
- Included Qty
- 2
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years
