From surfing the web to updating your Facebook - you'll be mousing on more surfaces thanks to Logitech optical. No delays, dropouts or hassles. The plug-and-forget nano-receiver keeps you connected with reliable wireless.
Logitech optical tracking
Enjoy precise clicking and pointing - on surfaces other optical mice can't handle - while navigating your favorite websites thanks to Logitech optical tracking. -
Logitech 2.4 GHz wireless connectivity
You get the reliability of a cord with wireless convenience and freedom - fast data transmission and virtually no delays or dropouts. -
Plug-and-forget nano-receiver
So small and unobtrusive, you can plug it into a USB port and forget about it. Plus, you can say good-bye to worries about broken or lost receivers. -
Compact comfort
You'll enjoy more comfort and ease thanks to this compact mouse's hand-friendly, contoured design with soft rubber grips and a smooth scroll wheel. -
Perfect for laptops and notebooks
No matter what type of computer you own - you can depend on your mouse to work like you expect.
- Logitech M235 - 2nd Generation - mouse - 2.4 GHz - pink ivory
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Pink ivory
- Orientation
- Right and left-handed
- 5 cm x 9 cm x 3.3 cm
- 86 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Movement Resolution
- 1000 dpi
- Scrolling wheel, rubber side grips, battery indicator, on/off power switch, Logitech Unifying receiver, Logitech Advanced Optical Tracking
- Battery
- 1 x AA type
- OS Required
- Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later, Windows 8
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
- Wireless Receiver
- Orientation
- 5 cm
- 9 cm
- 3.3 cm
- 86 g
- Pink ivory
Input Device
- Wireless
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 25 m
- Optical
- 1000 dpi
- 1 x USB - 4 pin USB Type A
- USB 2.0 Full-Speed
- AA type
- Technology
- Alkaline
- Installed Qty
- 1
- Run Time (Up To)
- 1 year
- OS Required
- Limited warranty - 3 years
