A wireless mouse with a tiny, leave-in receiver and laser tracking that works wherever you do--even on glass.
Darkfield Laser Tracking™
You get accurate, precise cursor control on virtually any surface, even glass tables (4 mm minimum thickness) where optical and standard laser mice fail. Turn the world into your mouse pad.
Logitech® Unifying receiver
The tiny receiver stays in your notebook. Plus, you can easily add a compatible wireless mouse or keyboard--without the hassle of multiple USB receivers.Learn more about the Unifying receiver.
Compact, ergonomically designed
The compact, ergomomic design helps keep you comfortable wherever you want to use your laptop--at home, at work, or on the go.Comfortable hands like comfortable mice.
Hyper-fast scrolling
You'll fly through documents and Web pages with a single spin. Click-to-click scrolling gives you the precision you need when navigating lists, slides, and images.Excited about hyper-fast scrolling?
Integrated thumb buttons
There's more control within your reach. Move quickly backward or forward through Web pages and within applications.Change the cursor speed? Change the cursor? Change the programmable buttons? Find out more about SetPoint™ software.
Logitech® Advanced 2.4 GHz wireless
You get the reliability of a cord with cordless convenience and freedom--fast data transmission and virtually no delays or dropouts. Learn more about Logitech wireless technologies.
Logitech Darkfield Laser Tracking
You get accurate, precise cursor control on virtually any surface, even glass tables (4 mm minimum thickness) where optical and standard laser mice fail. -
Fly through long documents and Web pages with a single spin. Or use click-to-click scrolling for the precision you need when navigating lists, slides, and images. -
Logitech advanced 2.4 GHz wireless
You get the reliability of a cord plus cordless convenience and freedom - fast data transmission and virtually no delays or dropouts. -
Logitech unifying receiver
The tiny receiver stays in your notebook. There's no need to unplug it when you move around, so your mouse is always connected when and where you feel like using it. Plus, you can easily add a compatible wireless keyboard or number pad, or even another mouse - without the hassle of multiple USB receivers. -
Comfortable even on the go
Small enough to take with you, the sculpted shape fits your fingers for a naturally comfortable grip. -
Back and forward thumb buttons
There's more control within your reach. Move quickly through web pages.
- Logitech Anywhere MX - mouse - 2.4 GHz
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Laser
- Logitech Darkfield Laser Tracking, Logitech Unifying receiver
- Battery
- 2 x AA type
- OS Required
- Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
- Wireless Receiver
Input Device
- Wireless
- Interface
- 2.4 GHz
- Laser
- 1 x USB - 4 pin USB Type A
- Included Accessories
- Carrying pouch
- AA type
- Installed Qty
- 2
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 3 years
