Linksys E2500 5-Port Gigabit Ethernet Switch
Quicklinx: 7QDNWS00 Mfr#: SE2500-UK
Upgrade your current Ethernet network to the power of Gigabit and improve your network performance.
Get speeds up to 10x faster than Fast Ethernet - perfect for quick file and media sharing between Gigabit devices.
Plug & PlayThis compact switch is designed to conserve desktop space and is easy to use - no configuration required. Simply connect computers, HDTVs, game consoles, media players and more, to instantly expand your home network.
Quality of ServiceQoS traffic prioritization technology delivers high performance so you can enjoy smooth video streaming and gaming.
Auto-sensing ports automatically optimize speed for each connected device.
Power SavingIncludes special features for optimal power efficiency.
-Auto power-down disables unused ports
-Sleep mode when all ports are inactive
-Smart power for short cable runs
-Port status switch to control LED lights
  • Benefits of Gigabit
    Upgrade your current Ethernet network to the power of Gigabit and improve your network performance. Get speeds faster than Fast Ethernet - perfect for quick file and media sharing between Gigabit devices.
  • Plug and play
  • Quality of Service
    QoS traffic prioritization technology delivers high performance so you can enjoy smooth video streaming and gaming. Auto-sensing ports automatically optimize speed for each connected device.
  • Power saving
Header / Model
SE2500
General / Product Type
Ports
5
Data Transfer Rate
1000 Mbps
Managed
no
Connection Type
RJ45
Dimensions & Weight / Depth
135 mm
Dimensions & Weight / Height
60mm
Dimensions & Weight / Weight
.41 kg
Dimensions & Weight / Width
255 mm
Environmental Parameters / Max Operating Temperature
40 Celcius
Environmental Parameters / Min Operating Temperature
0 Celcius
Flash Memory / Installed Size
192KB
Flash Memory / Technology
Packet memory
Flash Memory / Type
Packet memory
Header / Country Kits
Header / Localization
Header / Manufacturer
Linksys
Header / Packaged Quantity
1
Interface Provided / Connector Qty (Network)
5
Interface Provided / Connector Type
RJ45
Interface Provided / Type
RJ45
Interface Required / Connector Qty
5
Interface Required / Connector Type
RJ45
Interface Required / Total Qty
5
Interface Required / Type
RJ45
Miscellaneous / Colour
Miscellaneous / Compliant Standards
"CE Mark, EN 55022 Class B,
7QDN C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
