LG Electronics M38A 20" 1600x900 5ms VGA LED Monitor
Quicklinx: C0MFWS00 Mfr#: 20M38A
Protect Your Eyes and View in Comfort
Flicker Safe and Reader Mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero.
Preset Customized Options with just a Click
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse.
Customize Your Workspace for Multitasking
Screen Split divides the display for different tasks by resizing the windows on the screen. With PIP Mode you can work while watching a video in a window floating on the screen.
Offers Improved Color Vision to Color Weakness
Color revision algorithms are used to help those with color weakness who have difficulty distinguishing certain ranges of colors can view all the important content.
  • Protect your eyes and view in comfort
  • Preset customized options with just a click
  • Customize your workspace for multitasking
LG 20M38A - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.262 mm
Brightness
200 cd/m²
Contrast Ratio
5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1976)
Input Connectors
VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Textured black, black hairline front and base, black high glossy stand
46.3 cm x 16.78 cm x 35.88 cm
2.2 kg
Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, EPA 6.0
Display Type
Diagonal Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.262 mm
Brightness
200 cd/m²
Contrast Ratio
5000000:1 (dynamic)
Colour Support
Colour Gamut
72% (CIE 1976)
Response Time
5 ms (On/Off)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Hindi, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
Picture Mode, On-screen Digital Controls, 4-screen split, Flicker Safe, Reader Mode, Smart Energy Saving technology, Intelligent Auto, Color Weakness Mode
46.3 cm x 16.78 cm x 35.88 cm - with stand
2.2 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
75 x 75 mm
Key lock
Stand
Input Voltage
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Windows 10
Dimensions & Weight Details
With stand - width: 46.3 cm - depth: 16.78 cm - height: 35.88 cm - weight: 2.2 kg , Without stand - width: 46.3 cm - depth: 5.74 cm - height: 28.65 cm - weight: 2 kg
