LG Electronics Hi-Fi Audio Multi Room Speaker  Grey Bluetooth
Quicklinx: C3SYWS00 Mfr#: NP8740-H7
Synchronize your multi-room speakers together to play the same song in every room or to suit all your family's music tastes, stream different tracks around the house.
As soon as you arrive home, LG MUSIC flow syncs with your devices via Wi-Fi so you can continue listening to your music seamlessly. Just tap an NFC compatible device against your MUSIC flow speakers to add them to the network for music that follows you around the home.
  • Music that flows around your home
  • Sync automatically with all your devices
  • High definition sound
    Listen to your music in high definition sound quality and play high quality lossless compressed files.
  • Music flow player
    The LG MUSIC flow Player is more than just a remote letting you play music from multiple devices and connect to your favorite streaming sites. Whenever you're at home or not, LG MUSIC flow Player gives you complete control over what you want to play.
  • Home cinema mode
    Simply add an LG MUSIC flow soundbar to your network and synchronize it with your LG MUSIC flow speakers to enjoy a home cinema experience.
  • Seamless streaming
    LG MUSIC flow provides a stable connection, delivered via Wi-Fi technology without the risk of interruptions.
LG MUSIC flow H7 - speaker - wireless
Speaker
Speaker Type
Active
Continuous Power
70 Watt
Amplifier
Integrated
Bluetooth, Wi-Fi, NFC
DLNA
37 cm x 11 cm x 23.2 cm
4.1 kg
Speaker
Speaker System
Speaker Type
Active
Continuous Power
70 Watt
Amplifier
Integrated
Bluetooth, Wi-Fi, Near Field Communication (NFC)
DLNA
Controls
Power on/off, volume
Connector Type
LAN , Audio line-in (mini-phone stereo 3.5 mm)
AC power adaptor
Power Source
AC power adapter
37 cm
11 cm
23.2 cm
4.1 kg
