Cross display boundaries freely and without hassle. With LG Smart Share, mirroring the screen between LG TV and other smart devices is made incredibly easy and user-friendly.
You don't have to worry about missing your favorite shows anymore. With the LG's popular time machine feature, TV programs can be recorded so that you can rewind, pause, or re-watch your favorite shows.
Enjoy seamless home entertainment with Wi-Fi built-in. Just like a smartphone, LG Smart TV has a Wi-Fi chip built in the system, allowing greater connectivity and access to and from the TV.
Contents share
Freely share and access various content on different devices, whether you are in or outside your home. LG's Smart Share make it simple to connect devices within the house. With your own LG account, a simple log in can let you access your entertainment away from home. -
Universal search
Find anything you want at any time. Just type or speak in any keyword and the universal search will instantly provide a relevant listing of VOD content, broadcast programs and online videos from YouTube. The best search function ever, it allows you to find anything on your TV, and enrich your entertainment experience with LG Smart TV. -
Screen share
Cross display boundaries freely and without hassle. With LG Smart Share, mirroring the screen between LG TV and other smart devices is made incredibly easy and user-friendly. -
Time machine II
You don't have to worry about missing your favorite shows anymore. With the LG's popular time machine feature, TV programs can be recorded so that you can rewind, pause, or re-watch your favorite shows. -
Wi-Fi built-in
Enjoy seamless home entertainment with Wi-Fi built-in. Just like a smartphone, LG Smart TV has a Wi-Fi chip built in the system, allowing greater connectivity and access to and from the TV. -
IPS panel
Knock it to know it. The secret behind LG TV's superior viewing angle and quality is the panel. Just as the quality of the beans determines the quality of the coffee, the quality of the panel determines the quality of the TV. The IPS panel used by LG is the reason why LG LED TVs have clearer, more consistent, and sturdy screens. -
True color accuracy
IPS offers the most identical color impression to that of the original image in every precise pixel of HD resolution. -
Wide viewing angle
IPS minishows the most consistent color and contrast from all angles among LCD panels. -
Blur-free clarity
IPS is decidedly superior to the conventional panels in the clarity of its pictures during fast motion display, allowing blur-free, crystal-clear pictures. -
Stable screen
IPS panels are stable and study, and resistant to damage, as opposed to weak competing panels; just try a simple knock or poke at the screens to see for yourself. -
Triple XD engine
Enjoy sheer perfection of color, contrast, and clarity with the all-powerful triple XD engine. LG's most advanced triple XD engine brings the highest level of excellence in color, contrast, and clarity for the best picture quality and performance. -
Picture wizard III
Picture wizard III allows you to easily adjust picture elements such as black level, color, tint, sharpness and backlight levels. -
Virtual surround plus
Virtual surround plus, mimicks surround sound while adding a top-down sound effect. This top-down effect gives the listener the sensation that sound is streaming from the ceiling right above them. With sound pouring in from nearly all directions a more realistic three dimensional sound can be experience. -
Clear voice II
Enjoy clear and audible dialog with clear voice II. Clear voice II automatically recognizes and enhances the volume of human voices in movies and shows to make them more audible against background sound. -
Smart sound mode
Hear the most optimized sound for any entertainment. Set your sound settings to smart sound mode and it will automatically select the right sound EQ for the content that you watch on TV. Whether it be music, movies, sports, or games, you no longer have to choose a sound mode as the TV will do it for you, allowing you to enjoy the best sound for your entertainment. -
USB movie
Simply connect your USB or external hard drive to the USB port to play its contents on your TV screen. -
DivX HD
LG TVs are DivX certified, and can play DivX video up to 1080p HD. Enjoy the vast variety of premium content from the Internet through DivX HD. -
Smart energy saving
The smart energy saving feature helps users to be a little greener by limiting power consumption. The feature includes backlight control for adjusting brightness, a screen-off function that turns the picture off for playing audio-only, and the standby mode zero function which allows the TV to effectively hibernate, using zero electricity.
- LG 42LB580V 42" LED-backlit LCD TV - Full HD
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 42"
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Frame Rate & Enhancement Technology
- 100 Hz Motion Clarity Index
- Video Interface
- Component, HDMI, SCART
- HDMI Ports Qty
- 3 ports
- Connectivity
- Wi-Fi, LAN
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Internet Streaming Services
- NetCast, Smart TV Premium, LG Cloud, Social Center
- Speaker System
- 2 speakers
- Sound Effects
- Virtual Surround Plus
- USB
- 3 ports
- Included Accessories
- Universal remote
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A+
- Power Consumption (On mode)
- 52 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 76 kWh
- Dimensions (WxDxH) - without stand
- 96.1 cm x 5.55 cm x 56.7 cm
- 9.2 kg
- Product Type
- Energy Class
- Class A+
- 52 W
- 76 kWh
- Diagonal Class
- 42"
- TV Tuner Presence
- Extended PVR
- Sensors
- Intelligent sensor
- Video Interface
- HDMI Ports Qty
- 3 ports
- HDCP Compatible
- Dimensions
- Without stand
- 96.1 cm
- 5.55 cm
- 56.7 cm
- 9.2 kg
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- LED backlight
- Time-shift, Time Machine II, Picture Wizard III, Triple XD Engine
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 400 x 400 mm
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Teletext
- Teletext Memory
- 2000 pages
Media Player
- Supported Video Formats
- DivX HD
- USB Port
- USB Ports Qty
- 3
Remote Control
- Universal remote
- Smart phone remote support, LG Magic Motion Remote Control Ready
Audio System
- Digital Audio Format
- Dolby Digital output, DTS digital output
- Surround Mode
- Sound Effects
- Audio Controls
- Sound mode
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Built-in DTS decoder, built-in Dolby Digital decoder, Clear Voice II technology, Sound Optimizer, Smart Sound
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
- Connectivity
- Wi-Fi, LAN
- Connect & Share
- Wi-Fi Direct, Mobile High-Definition Link (MHL), Intel Wireless Display (WiDi), Wi-Fi Miracast, Smart Share
- Supported Consumer Electronics Control (CEC)
- Simplink
- Application Store
- LG App Store
- DLNA
- Connector Type
- 3 x HDMI - side , SCART - rear , Component video input - rear , 3 x USB 2.0 - side , Digital audio output (optical) - rear , Audio line-in - rear , Headphones - rear , Audio line-in - rear , LAN - rear
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
- Smart energy saving
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 96.1 cm x 5.55 cm x 56.7 cm x 9.2 kg , Panel with stand - 96.1 cm x 21.8 cm x 61 cm x 9.5 kg
