With comfort, have everyone enjoy the fine visual quality of a 21:9 ratio wide screen in your room. Watch your movies or surf the web. You will be astonished by the great visual quality of IPS UltraWide Full HD. Enjoy a panoramic theater experience from your couch.
25UM65's 21:9 ratio provides a better environment for multitasking in comparison to 23-inch 16:9 monitors. You will see the full lengths of your spread sheets, and be able to research in a separate window, spaciously located beside it. Maximize your work efficiency and eliminate scrolling and window switching.
21:9 UltraWide Full HD
With comfort, have everyone enjoy the fine visual quality of a 21:9 ratio wide screen in your room. Watch your movies or surf the web. You will be astonished by the great visual quality of IPS UltraWide Full HD. Enjoy a panoramic theater experience from your couch. -
21:9 ratio
25UM65's 21:9 ratio provides a better environment for multitasking in comparison to 23-inch 16:9 monitors. You will see the full lengths of your spread sheets, and be able to research in a separate window, spaciously located beside it. Maximize your work efficiency and eliminate scrolling and window switching. -
Triple monitor
When you connect UltraWide to your laptop as a dual monitor, it provides not one but two separate and large screens. In a narrow workspace with your laptop, now you can have three screens to work with three different programs. Put Outlook and PowerPoint on the UltraWide, and freely cruise the Internet on your laptop. A convenience unthinkable with conventional 16:9 monitors. -
Reader mode
Reducing blue light to protect your eyes, reader mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for as long as you would like to. -
IPS display
As LG IPS monitor features consistency and less changes in color temperature, it offers a color impression identical to that of the original image. You can enjoy lifelike picture quality without any color shift whether you are standing or lying down. It allows you to enjoy any content, such as action movies, web surfing and RPG games for a long time in comfort. -
Flicker safe
Protect your eyes from exhausting flickers and blue lights. LG's flicker safe system is always on to reduce the flicker level to almost-zero. In addition, activate the reader mode to minimize harmful blue lights with a simple touch of a hot-key. Spend as long as you want working, gaming, or watching movies without burdening your eyes. Use the convenient and easy hot keys for more satisfaction. -
Joystick
The joystick is a harmony of accurate menu controls and analog sensitivity. With the fun control of a conventional joystick, its modern technology and design allow for simple control with a pleasant touch. In addition, intuitive UI with no overlapping is easier to understand and select menus.
- LG 25UM65-P - LED monitor - 25"
- LED-backlit LCD monitor - 25"
- Energy Class
- Class B
- Energy Consumption per Year
- 45 kWh
- Power Consumption (On mode)
- 31 W
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Full HD 2560 x 1080
- Pixel Pitch
- 0.2286 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 5000000:1 (dynamic)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, DVI-D, DisplayPort
- Speakers
- Integrated
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V
- High glossy black
- 60.9 cm x 18.84 cm x 38.3 cm
- Plug and Play, FCC Class B certified, UL, BSMI, cUL, CCC, DDC/CI, RoHS, REACH, KC
- Display Type
- Energy Class
- Class B
- 45 kWh
- Diagonal Size
- 25"
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.2286 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Picture by picture, sRGB colour management, HDCP
- High glossy black
- 60.9 cm x 18.84 cm x 38.3 cm - with stand
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 3 Watt
- 2 x HDMI , DVI-D , DisplayPort , Headphones , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- Cables Included
- 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- 31 W
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 60.9 cm - depth: 18.84 cm - height: 38.3 cm , Without stand - width: 60.9 cm - depth: 4 cm - height: 28.14 cm
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
