The LG IPS Monitor ensures an awesome picture quality that provides clear images and vivid colors from any angle. LG's IPS Monitor provides accurate color for your viewing pleasure.
The 4-Screen Split feature improves productivity by simply re-sizing the windows on your screen. With one drag you can re-size one window and the other windows automatically to fir the available space. It allows from 2 to 4 windows to be shown in 8 different screen ratios without feeling cluttered.
It's easy to build up a multi-tasking environment with multiple monitors. Color Coloring APP helps you to match the color quality and brightness between two LG monitors that are connected to the same PC.
IPS display
The LG IPS Monitor ensures an awesome picture quality that provides clear images and vivid colors from any angle. color Calibration tests were conducted before the monitors are handed over to consumers. LG's IPS Monitor provides accurate color for your viewing pleasure. -
Cinema Screen design
The Cinema Screen design offers an immersive experience both in terms of form and content. Thanks to its elegant design, it also delivers an aesthetic value of its own. -
4-Screen Split
The 4-Screen Split feature improves productivity by simply re-sizing the windows on your screen. With one drag you can re-size one window and the other windows automatically to fir the available space. It allows from 2 to 4 windows to be shown in 8 different screen ratios without feeling cluttered. -
Color Cloning
It's easy to build up a multi-tasking environment with multiple monitors. Color Cloning APP helps you to match the color quality and brightness between two LG monitors that are connected to the same PC. -
Color Wizard
The color Wizard feature prevents color-weak people from missing important content by distinguishing certain ranges of colors via the color revision algorithm. -
Flicker Safe
Reducing the flicker level to almost zero, Flicker-Safe helps you protect your eyes from exhausting flickers. Work and entertain as long as you want with the IPS monitor. -
Reader Mode
Reader Mode provides optimal reading conditions by reducing harmful blue light from LED backlight. You can comfortably read from the monitor - for as long as you want.
- LG 23MP67VQ - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Energy Class
- Class B
- Energy Consumption per Year
- 35 kWh
- Power Consumption (On mode)
- 24 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Screen Coating
- Anti-glare, 3H Hard Coating
- 53.3 cm x 20.5 cm x 42.6 cm
- Plug and Play
- Display Type
- Energy Class
- Class B
- 35 kWh
- Diagonal Size
- 23"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- CINEMA Screen Design, Smooth Color Change, Lifelike Color, 4-screen split, Flicker Safe, Color Cloning, Smart Energy Saving technology, Color Wizard
- 53.3 cm x 20.5 cm x 42.6 cm - with stand
- HDMI , DVI-D (HDCP) , VGA , Headphones
- Plug and Play
- Power Supply
- Internal
- 24 W
- Power Consumption (Typical)
- 23 Watt
- Power Consumption Stand by
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 53.3 cm - depth: 20.5 cm - height: 42.6 cm , Without stand - width: 53.3 cm - depth: 5.2 cm - height: 32.4 cm
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black | In Stock | £14.57 |
