LG Electronics 23" 3D Ready LED Wide Monitor
Quicklinx: 7Q37WS00 Mfr#: D2342P-PN
  • High-Definition Multimedia Interface (HDMI)
TURN YOUR 2D WORLD INTO 3D THROUGH A FULL HD EXPERIENCE
Redefine standards with the LG D42P, a full HD LED wall mountable 3D monitor, with a stylish slim design created for a new level of experience. Using its 3D player you can transform photos, home videos or even movies, from 2D to 3D at the touch of a button. The D42P revolutionises the way you watch home content; giving you the power to watch 3D at will.
  • Certified flicker-free
    No more dizziness, nausea, or discomfort. LG's Cinema 3D technology eliminates flickering shutters from glasses, allowing you to freely indulge in 3D images for an extended period of time without dizziness or weariness.
  • Crosstalk free
    While LG's 3D technology enables the glasses to eliminate flickering images, the 3D panel provides clearer, blur-free images. Enjoy a superior viewing experience with no overlapping images, or dizziness associated with conventional 3D technology.
  • Electron waves free
    LG's Cinema 3D glasses are battery-free, generating no harmful electron waves. This provides a convenient environment for users to enjoy 3D contents for as much as time wanted.
  • Ultimate 3D brightness
    More than two times brighter than conventional 3D monitors, LG's 3D technology provides brighter and clearer images. LG's 3D technology is able to counteract any dimness that can occur within 3D images through a special, thin film that covers the screen. LG's 3D monitor also produces exceptionally clear and vivid images in 2D as well.
  • 3D effect mode
    D2342P provides a much vivid and clear 3D image through the 3D effect mode. Contrast ratio and sharpness were improved to provide brighter and clearer 3D picture quality. This adjustment enables to sharpen the boarders of dark images allowing users to experience and feel greater depth in 3D.
  • 2D to 3D conversion
    D2342P allows any 2D images to convert in to a 3D view through a software provided with the monitors. 2D-3D conversion enables the enjoyment of 3D through any contents.
  • HDMI connectivity
    Interface is supported to connect 3D devices with LG's Cinema 3D monitor. This makes it possible to view any 3D contents even without a PC. Direct connection is available with game console, Blu-ray player, set-top box to enjoy 3D contents.
  • Super Energy Saving
    LG's Super Energy Saving technology enables the product to lower power consumption without any image loss.
LG D2342P-PN - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.256 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 120/230 V
Glossy piano lacquer black
54.6 cm x 17.9 cm x 40.7 cm
3.5 kg
Plug and Play, DDC/CI
Display Type
Diagonal Size
23"
3D Technology
Polarization
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.256 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Sync on Green, f-ENGINE technology, HDCP, SUPER Energy Saving Technology, CINEMA 3D technology, 2D to 3D conversion
3.5 kg
VGA , DVI-D , HDMI , Headphones
Mechanical
Tilt
Tilt Angle
20
VESA Mounting Interface
2 FPR 3D glasses
1 x VGA cable , 1 x DVI cable
Input Voltage
AC 120/230 V
Power Consumption (Typical)
33 Watt
Power Consumption Stand by / Sleep
0.5 Watt
