TURN YOUR 2D WORLD INTO 3D THROUGH A FULL HD EXPERIENCE
Redefine standards with the LG D42P, a full HD LED wall mountable 3D monitor, with a stylish slim design created for a new level of experience. Using its 3D player you can transform photos, home videos or even movies, from 2D to 3D at the touch of a button. The D42P revolutionises the way you watch home content; giving you the power to watch 3D at will.
- LG D2342P-PN - 3D LED monitor - 23"
- LED-backlit LCD monitor - 23"
- 3D Capable
- Panel Type
- TN
- Aspect Ratio
- Widescreen - 16:9
- Native Resolution
- FullHD 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.256 mm
- Brightness
- 250 cd/m2
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Glossy piano lacquer black
- 54.6 cm x 17.9 cm x 40.7 cm
- 3.5 kg
- Plug and Play, DDC/CI
- Display Type
- Diagonal Size
- 23"
- 3D Capable
- 3D Technology
- Polarization
- Panel Type
- TN
- Aspect Ratio
- Widescreen - 16:9
- Native Resolution
- Pixel Pitch
- 0.256 mm
- Brightness
- 250 cd/m2
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- WLED
- Sync on Green, f-ENGINE technology, HDCP, SUPER Energy Saving Technology, CINEMA 3D technology, 2D to 3D conversion
- 3.5 kg
- VGA , DVI-D , HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- 20
- Flat Panel Mount Interface
- Included Accessories
- 2 FPR 3D glasses
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Voltage Required
- AC 120/230 V
- 33 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
