As LG IPS Monitor features consistency and less changes in color temperature, it realize a color impression identical to its original image. Reducing blue light to protect your eyes, reader mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for long.
Lifelike color
As LG IPS Monitor features consistency and less changes in color temperature, it realize a color impression identical to its original image. -
Reader mode
Reducing blue light to protect your eyes, reader mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for long. -
Flicker-safe
The dimming technology is applied to minimize the flicker level causing eye fatigue. With almost-zero flicker technology, you'll be able to watch longer, comfortably. -
Wide viewing angle
LG IPS Monitor allows you to enjoy lifelike picture quality without any color shift whether you are standing or lying down. -
Smooth color change
Smooth color change allows you to enjoy any content, such as action movies, web surfing and RPG games for a long time in comfort. -
SUPER Energy Saving
LG SUPER Energy Saving technology has been upgraded so that the additional energy saved besides the effect of the LED backlight, has improved from 25% to 30%. -
SUPER+ Resolution
SUPER+ Resolution technology helps to detect rough edges and blurring in contents when enlarged, offering improved quality with a better sense of high resolution.
- LG 22MP55HQ-P - LED monitor - 21.5"
- LED-backlit LCD monitor - 21.5"
- Aspect Ratio
- Widescreen
- Native Resolution
- 1920 x 1080
- Brightness
- 250 cd/m2
- Contrast Ratio
- 1000:1
- Tilt
- - with stand
- Display Type
- Diagonal Size
- 21.5"
- Aspect Ratio
- Widescreen
- Native Resolution
- 1920 x 1080
- Brightness
- 250 cd/m2
- Contrast Ratio
- 1000:1
- - with stand
Mechanical
- Tilt
- Voltage Required
- AC 120/230 V
