Reader Mode
Reader Mode provides optimal reading conditions by reducing harmful blue light from LED backlight. You can comfortablly read from the monitor - for as long as you want.
Flicker Safe
Reducing the flicker level to almost zero, Flicker-Safe helps you protect your eyes from exhausting flickers. Work and entertain as long as you want!
Colour Wizard
The Colour Wizard feature prevents colour-weak people from missing important content by distinguishing certain ranges of colours via the colour revision algorithm.
Smart Energy Saving
LG Smart Energy Saving technology has been upgraded so that the additional energy saved besides the effect of the LED backlight, has improved. * Conserve energy by adjusting screen brightness
- LG 22M37A-B - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Black
- 50.9 cm x 18.1 cm x 38.7 cm
- 2.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Screen Coating
- Backlight Technology
- WLED
- Dual web, Smart Energy Saving technology, Color Wizard
- Black
- 50.9 cm x 18.1 cm x 38.7 cm - with stand
- 2.6 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 75 x 75 mm
- Cables Included
- 1 x VGA cable
- Power Supply
- External
- Power Consumption (Typical)
- 18 Watt
- Power Consumption Stand by
- 0.3 Watt
- OS Required
- Windows 8
- Dimensions & Weight Details
- With stand - width: 50.9 cm - depth: 18.1 cm - height: 38.7 cm - weight: 2.6 kg , Without stand - width: 50.9 cm - depth: 5.7 cm - height: 31.6 cm - weight: 2.4 kg
Sustainability Information
- ENERGY STAR Certified
