The Lexar Echo MX backup drive is an easy-to-use, ultra-portable drive with capacity meter, which provides a convenient way to quickly and automatically back up and protect your files on the go.
Designed for netbook and notebook users, the Lexar Echo MX is a high-capacity, high-performance, flash-based backup drive that easily plugs into your system's USB port to provide automatic backup of your files. Built-in Lexar Echo backup software activates as soon as it's plugged in, to securely and automatically protect files with 128-bit AES encryption. The drive also performs ongoing backups to any files in use, and restores previously saved versions of a file providing peace of mind that your data is safe.
In addition to its compact design with an integrated sleeve cap that reveals the USB connector, the Lexar Echo MX backup drive sports an easy-to-read, always-on capacity meter that lets you determine your available backup space at a glance, and maintains the reading even when disconnected - for ultimate convenience.
- Lexar Echo MX Backup Drive - USB flash drive - 128 GB
- Product Type
- USB flash drive
- Storage Capacity
- 128 GB
- Interface Type
- USB 2.0
- Encryption
- 128-bit AES
- Software Included
- Lexar Echo Backup Software
- 5 years warranty
- Product Type
- USB flash drive
- Storage Capacity
- 128 GB
- Encryption
- 128-bit AES
- Compatibility
- Non-specific
- Speed Rating
- 30 MB/s (read) 17 MB/s (write)
- Interface Type
- USB 2.0
- Backup, capacity meter
- Software Included
- 5 years warranty
- Service & Support Details
- Limited warranty - 5 years
