The ThinkPad USB 3.0 Pro Dock delivers a professional universal USB docking solution with fast USB 3.0 ports and digital video ports for quick and easy connection to all of the workspace peripherals you use every day. Simply plug a single USB 3.0 cable into your Lenovo PC for instant access to up to two external monitors, Gigabit Ethernet, headphones/speakers, USB printers, scanners, keyboard, mouse and more for daily use. The dock can also charge your mobile device via the always-on USB port.
Dock requires AC power to operate.
- Lenovo ThinkPad USB 3.0 Pro Dock - docking station - USB - DP - GigE
- Product Type
- Docking station
- Docking Interface
- USB
- Video Interfaces
- DP
- 15 cm x 8 cm x 3.2 cm
- 236 g
- Localisation
- United Kingdom, Ireland
- Networking
- Gigabit Ethernet
- Power
- Power adapter AC 120/230 V (50/60 Hz) 45 Watt Power Provided
- 3-year warranty
- Product Type
- Docking station
- 15 cm
- 8 cm
- 3.2 cm
- 236 g
- Localisation
- Data Link Protocol
- Gigabit Ethernet
- 1 x SuperSpeed USB 3.0 - 4 pin USB Type B , 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x audio / video - DisplayPort - 20 pin DisplayPort , 1 - DVI-Analog/Digital - 24+5 pin combined DVI , 1 x network - RJ-45 , 1 x audio - headphones/microphone - mini-phone stereo 3.5 mm
- Cables Included
- 1 x DVI-I to VGA adapter - external , 1 x SuperSpeed USB cable - external - 1 m
- Security lock slot (cable lock sold separately), VESA interface support, 1 USB 3.0 (Always On)
- UL, TUV, VCCI, BSMI, cUL, SABS, CB, DOC, FCC, SII, KCC, ICES, Kvalitet, EAC, RCM
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Power Provided
- 45 Watt
- Limited warranty - 3 years
- -5 °C
- 40 °C
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £15.80 |
