Powered for productivity, the ThinkCentre M93p family is a great choice for large organizations that need the utmost in reliability, power, and data security.
Specs
CORE I5-4570 84W HASWELL 3.2G 6M 4C LGA1150 HF ITT VT-DX
4GB 1600MHZ UDIMM DDR3 PC3-12800
SFF 240W 85% SINGLE OUTPUT/Q87 VPRO READY WW
500GB 7200RPM SATA3 3.5\"
DVD BURNER/CD-RW RAMBO DRIVE (SATA) - WINDOWS 7
LENOVO ENHANCED OPTICAL USB MOUSE
W8P64 DG W7P64 WW EN
Windows 8 Pro64 RDVD WW EN
THERMAL KIT 65W SFF
INTEL 4TH GEN PROCESSOR LABEL - CORE I5 VPRO ONYX
WINDOWS 8 64BIT PRO LOGO GML
L1 COPT ENERGY STAR
Platform Stability
The M93p desktop features 15-month platform stability with no planned hardware changes that affect the preloaded software image. Image stability for long-term deployments helps to reduce transition, qualification, and testing costs to ensure savings for your business. -
Multiple monitor display
Maximize productivity with independent display support for up to three monitors. The expanded work area and easier navigation between applications helps reduce errors and improve productivity as you extend your desktop across multiple displays. -
Solid security and manageability
M93p desktop includes some of the best security tools available in the industry, including USB ports disablement to help prevent data theft and network security risks against unauthorized use of storage devices. Trusted Platform Module (TPM) encrypts data and key information like passwords and digital certificates, further securing applications, electronic transactions, and online communication. Plus the M93p desktop includes a chassis intrusion switch, which alerts against any unauthorized access attempts. -
SuperSpeed USB 3.0
Enables up to 10 times faster file transfer, allowing for lightning-fast copying of large media files, as well as seamless connections between audio- and video-related peripherals. -
Tool-less expandability
Upgrades are a cinch for IT staff, with convenient tool-free access to hardware. Especially beneficial when applied across multiple desktops. -
Advanced thermal design
The Intelligent Cooling Engine (ICE) 3.0 is designed to provide a balance between thermals and acoustics resulting in long desktop life. With two optimized settings, you choose the performance mode that best suits your work environment, prioritizing temperature or sound. Plus, ICE 3.0 allows for working in hotter temperatures and enables system monitoring with thermal alerts that preempt overheating possibilities. Manage ICE with PC Cloud Manager 2.0.
- Lenovo ThinkCentre M93p - SFF Pro - Core i5 4570 3.2 GHz - vPro - 4 GB - HDD 500 GB - UK
- Personal computer - small form factor pro - administrator password, hard drive password, power-on password, boot without keyboard or mouse, serial port I/O control, USB port control, boot sequence control, Intel Active Management Technology (iAMT)
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- Intel Core i5 (4th Gen) 4570 / 3.2 GHz (, up to 3.6 GHz, (Quad-Core)
- Processor Socket
- LGA1150 Socket
- Processor Main Features
- Intel Virtualization Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR3 SDRAM - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 4600
- Audio Output
- Stereo - integrated
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
- Software Included
- Cyberlink PowerDVD, CyberLink PowerProducer, CyberLink Power2Go, ThinkVantage Rescue and Recovery, Adobe Reader, Skype, ThinkVantage System Update, Lenovo Password Manager, Norton Internet Security (30 days subscription), ThinkVantage Product Recovery, Lenovo Message Center Plus, EverNote, ThinkVantage Communication Utility, ThinkVantage View Management Utility, Lenovo Solution Center, Lenovo Cloud Storage by SugarSync, Intel Small Business Advantage, Intel AppUp Center, Nitro Pro, Lenovo Desktop Power Manager
- Business black
- 33.8 cm x 37.5 cm x 10.2 cm
- 7.8 kg
- Manufacturer Selling Program
- Global Models Plus
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Limited warranty - 3 years - on-site - response time: next business day
- Personal computer
- Product Form Factor
- Small form factor pro
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Business black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.2 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel Q87
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- Max Monitors Supported
- 3
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Preferred Pro USB
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Integrated
- Ethernet Controller
- Intel I217-LM
- Data Link Protocol
- Wake on LAN (WoL)
- Bays
- 1 (total) / 0 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x internal 3.5" x 1/3H , 1 (total) / 1 (free) x external 3.5" x 1/6H
- Slots
- 4 (total) / 3 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCI - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode)
- 2 x USB 2.0 , 6 x USB 3.0 (2 front, 4 rear) , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x audio line-in , 2 x DisplayPort , 1 x audio line-out
- Administrator password, hard drive password, power-on password, boot without keyboard or mouse, serial port I/O control, USB port control, boot sequence control, Intel Active Management Technology (iAMT)
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- RoHS, GREENGUARD
- Power supply
- Voltage Required
- Power Provided
- 240 Watt
- Efficiency
- 85%
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
- Software
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 33.8 cm
- 37.5 cm
- 10.2 cm
- 7.8 kg
