Stop worrying about your battery: with the Lenovo S510p you can stay unplugged up to 5 hours with the standard 4-cell. Plus Lenovo Energy Manager protects the long-term durability of the battery and uses advanced energy-saving technology to increase time spent between charges.
Intel HD HD Graphics deliver powerful high-def performance. Or choose the optional NVIDIA GeForce discrete graphics processing unit (GPU) for efficiency and speedy performance for your HD videos and photos, immersive 3D movies, and entry level gaming.
Intel Core i processor
The Intel Core i processor delivers 11% faster performance than the previous generation processor, and with SSD technology and DDR4 memory, you'll experience extraordinary productivity. -
Big power in a small form-factor
The S510 has been put through over 200 reliability tests including shock, drop and vibrations tests in order to maximize both the life of the system and your ROI. -
Enhanced security
An array of security features such as Smart USB Protection, which restricts port access while allowing keyboard and mouse inputs, will provide you with peace of mind. -
Green and sustainable
The S510 has earned the green certifications of Energy Star 6.1, GREENGUARD, WEEE, and more. Green certification means decreased power consumption, which translates to lower power costs for your small business.
- Lenovo S510 - SFF - Core i3 6100 3.7 GHz - 4 GB - HDD 500 GB - UK
- Personal computer - small form factor
- Localisation
- Processor
- Intel Core i3 (6th Gen) 6100 / 3.7 GHz (Dual-Core)
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Card Reader
- 7 in 1
- Graphics Controller
- Intel HD Graphics 530
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Black
- 29.5 cm x 32 cm x 9 cm
- 4.13 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.7 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 3
Optical Storage
- DVD-Writer - SATA
Card Reader
- 7 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111GN
- Data Link Protocol
- Wake on LAN (WoL)
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 0 (free) x external
- Slots
- 2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x M.2 Card , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile
- 4 x USB 3.0 (2 front, 2 rear) , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x audio line-in , 1 x audio line-out
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- Efficiency
- 85%
Operating System / Software
- OS Provided
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 29.5 cm
- 32 cm
- 9 cm
- 4.13 kg
