The Lenovo LS2221 is a 21.5" full HD LED TFT monitor adopts the W-LED backlight technology and provides great display quality and saves power consumption. It offers digital visual interface (DVI) connectivity with high-bandwidth digital copy protection (HDCP) to deliver high-definition viewing of protected contents. It comes in a high gloss ID, transparent bezel, and touch OSD buttons. It has high display performance, such as high dynamic contrast ratio and Novo Vision. The Lenovo LS2221 is packed with green features including mercury free by adopting white LED backlights, arsenic-free glass, and is ENERGY STAR and TCO display compliant.
- Lenovo LS2221 - LED monitor - 21.5" - TopSeller
- LED-backlit LCD monitor - 21.5"
- Panel Type
- TN
- Aspect Ratio
- Widescreen - 16:9
- Native Resolution
- FullHD 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m2
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms
- Input Connectors
- DVI-D, VGA
- Tilt
- High-gloss black
- 52.5 cm x 18 cm x 39.1 cm
- 4 kg
- Localisation
- English / United Kingdom
- Manufacturer Selling Program
- TopSeller
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified , EPEAT Gold
- FCC Class B certified, VESA DPMS, RoHS, ISO 9241-307, WEEE, TCO Displays 5.2
- 3 years warranty
- Display Type
- Diagonal Size
- 21.5"
- Viewable Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- Widescreen - 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m2
- Contrast Ratio
- Response Time
- 5 ms
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- WLED
- HDCP, 72% colour gamut
- High-gloss black
- 4 kg
- DVI-D , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- Cables Included
- 1 x DVI cable - 1.8 m , 1 x VGA cable - 1.8 m
- Localisation
- TopSeller
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V ( 50/60 Hz )
- 18 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
- EPEAT Compliant
- EPEAT Gold
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years
