LaCie 6TB 2big Quadra USB 3.0 7200rpm
Quicklinx: 8G1PWS00 Mfr#: LAC9000354
This quadruple interface professional 2-disk RAID delivers fast speed, large capacity and data security. With eSATA 3Gbits, FireWire 800, FireWire 400 and Hi-Speed USB 2.0, it provides complete universal compatibility with any PC or Mac. The easy-to-use 2big Quadra comes with two extractable, lockable and hot-swappable disks for a user-controlled solution. With four RAID levels, it meets your storage needs, whether it's security, capacity, speed or a combination. With burst transfer rates as high as 165MB/s (eSATA), it's ideal for audio/video projects. The sturdy heat sink metal design provides 60% more surface area for natural heat dissipation.
LaCie 2big Quadra - hard drive array
Hard drive array
Total Array Capacity
6 TB
FireWire 800, USB 3.0
2 (installed) / 2 (max)
Storage Controller
RAID RAID RAID 0, 1
Storage Controller Quantity
1
Hard Drive
2 x 3 TB
Apple MacOS X 10.5 or later, Microsoft Windows Vista / XP / 7 / 8
50/60 Hz
9.1 cm x 17.2 cm x 20 cm
3.6 kg
3-year warranty
Hard drive array
Chassis
2
Supported Devices / Modules Qty
2
Storage
6 TB
HDD Array External Interface
Storage Controller
RAID - integrated
Installed Qty
1
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1
Storage Controller (2nd)
Installed Qty
1
Hard Drive
Plug-in module
2 x 3 TB
Spindle Speed
7200 rpm
2 x FireWire 800 - 9 pin FireWire 800 , 1 x USB 3.0
1 x USB 3.0 cable , 1 x IEEE 1394b cable
Software Included
Genie Backup Manager Pro, Intego Backup Manager Pro, LaCie Desktop Manager
Stand
External power adapter
50/60 Hz
9.1 cm
17.2 cm
20 cm
3.6 kg
Limited warranty - 3 years
