The LaCie Porsche Design P'9220 mobile hard drive is more than just a place to store your files-it's a collaboration between one of the most renowned design firms in the world and LaCie.
Since then the two companies have worked closely to create products that blend flawless functionality and pure design. The luxury brand and the leading technology company complement each other, with technical influence from LaCie, together with an exclusive and timeless shape presented by Porsche Design.
With the P'9220's USB 3.0 interface, you'll be able to transfer files faster than ever before-a 700 MB video file in just under 7 seconds! You can back up your photos, exchange audio and video files with your friends, or make sure that your important files are kept safe. With the speed of USB 3.0, the possibilities are endless.
Safe, strong, and aluminum Porsche Design is known worldwide for their sophisticated, timeless creations, and the P'9220 is no exception. With 3 mm of strong aluminum casing surrounding the drive inside, you can be sure that your data is solidly protected.
The ultimate blend of design and performance
The LaCie Porsche Design P'9220 mobile hard drive is more than just a place to store your files - it's collaboration between one of the most renowned design firms in the world and LaCie. -
- LaCie Porsche Design P'9220 - hard drive - 2 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 2 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Password authentication, automatic backup
- Power Source
- USB bus
- 2-year warranty
- Capacity
- 2 TB
- Interface
- USB 3.0
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- Software Included
- LaCie Backup Assistant, LaCie Private-Public, Wuala
- OS Required
- Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Microsoft Windows Vista / XP / 7 / 8
- Cables Included
- 1 x USB 3.0 cable - external
- Enclosure Material
- Aluminium
- Limited warranty - 2 years
