Your basket is empty
LaCie 1TB Hi-Speed USB 2.0 Desktop Hard Drive Design by Neil Poulton
Customer rating: 5.0* (Write a review)
Quicklinx: 4YFDWS00 Mfr#: 301304EK
The user-friendly LaCie Hard Disk, Design by Neil Poulton adds sophisticated style to your desktop, yet its presence is quiet and unobtrusive. It has a unique distinguishing feature--a blue LED strip on its underside that creates an ambient glow. Its subtle, all-black design blends perfectly into dark home entertainment setups and workstations. Very small for its vast capacity, this lightweight, compact drive has a fashionable, mirror-polished finish. The smartly engineered design allows for heat dissipation and near-silent, fanless operation. With Hi-Speed USB 2.0, this efficient external hard drive makes a great companion to your PC or Mac. Setup is nearly effortless; it's plug & play, offers customizable formatting, and comes with LaCie Backup Assistant and USB Boost.
-Compact and efficient USB 2.0 storage -Blue LED for ambient underside glow -Smart fanless cooling system for quiet operation -Store your files, music, photos and videos in one place -Design by Neil Poulton
Compact and Easy To Use
The efficient and simple LaCie Hard Disk, Design by Neil Poulton is compact and easy for anyone to use. Very small for its huge capacity, this lightweight drive has a fashionable, mirror-polished finish. Setup is nearly effortless; it's plug & play and offers customizable formatting with LaCie Setup Assistant. Genie® Backup Assistant for Windows® and Intego® Backup Assistant for Mac® are both included for saving files in one click.
Discreet Design and Function
The LaCie Hard Disk, Design by Neil Poulton adds sophisticated style to your desktop yet its presence is quiet and unobtrusive. This compact, sleek hard drive has a unique distinguishing feature -- a cool, blue LED strip on its underside that creates an ambient glow. Its smartly engineered design allows for heat dissipation and near-silent, fanless operation.
USB 2.0
With USB 2.0, this hard drive makes a great companion to your PC or Mac. Even use it as a reliable data shuttle between USB-equipped desktop and laptop computers. Advantages of USB 2.0 include: universal compatibility, cross-platform convenience, hot-pluggable connections, and good transfer rates.
Multiple Uses
The user-friendly LaCie Hard Disk, Design by Neil Poulton is a great storage tool for laptops or workstations. Use it to regularly back up your entire system or upgrade capacity when your computer's hard drive is full. Conveniently download digital photos and save all of your music files. Its subtle, all-black design blends perfectly into dark home entertainment setups and work stations.
Specification
  • Capacity: 1TB
  • Interface : Hi-Speed USB 2.0
  • Interface Transfer Rate : Up to 480Mbits/s (60MB/s)
  • Burst Transfer Rate : Up to 30-35MB/s
  • Fan : Fanless
  • Size : 4.6 x 7.6 x 1.8 in. / 117 x 193 x 45 mm
  • Weight : 33.5 oz. / 950 g
  • System Requirements : Computer with USB 2.0 (USB 1.1 compatible); Windows 2000, Windows XP, Windows Vista™ / Mac OS X 10.5 or higher; 32MB RAM minimum
  • Box Content : LaCie Hard Disk, Design by Neil Poulton, USB 2.0 cable, External power supply, Quick Install Guide
  • LaCie Utilities (preloaded on the drive): User Manual, LaCie Backup Assistant (Windows and Mac), LaCie Setup Assistant
  • Comments : 1 GB = 1,000,000,000 bytes. Total accessible capacity varies depending upon operating environment (typically 5-10% less).
  • Warranty : 2-Year Limited Warranty
Resources
The following resources are available for the LaCie 1TB Hi-Speed USB 2.0 Desktop Hard Drive Design by Neil Poulton
Customer reviews
Write a review for the LaCie 1TB Hi-Speed USB 2.0 Desktop Hard Drive Design by Neil Poulton here!
5.0 5
£42.44
Superb
Reviewed by . Review Posted 20/01/2009
5 5
Arrived on the day BT Business Direct said it would. Very quiet, slick piece of kit and works like a dream. Absolute bargain, thoroughly recommended.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
review
Reviewed by . Review Posted 04/01/2009
5 5
looks good, bit noisy. computer read it as a 10mb drive, then went into computer disk management to check what the problem was and not all the disk space had been partioned, eventually got the full 1tb (930mb)i think i should have read the instructions first as i deleted the backup software which would have configured the drive for me, anyway, works well
  • Overall 5*
  • Ease of use 4*
Excellent Valve
Reviewed by . Review Posted 29/10/2008
5 5
Bought one , I wish I bought two.Very good looking and alot smaller than I first thought. Looks lovely on my desktop.
  • Overall 5*
  • Ease of use 5*
Read all 5 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Click here
