For 4k and other bandwidth-hungry workflows, external storage needs to be fast, secure, reliable, and quiet. The LaCie 5big fits the bill, delivering thunderbolt 2 speeds for 4k video editing, up to 30 TB capacity, and hardware RAID 5/6 for no-compromise data security.
Thunderbolt 2 speeds for the 4k era
Game-changing storage performance that accelerates workflows. -
RAID for speed with security
Hardware RAID for optimal performance with data security. -
The powerful I/O, reinvented
Doubles the speed and supports 4k workflows. -
Advanced cooling for long-term reliability
Efficient and near-silent cooling for a long-lasting product.
- LaCie 5big Thunderbolt 2 - hard drive array
- Hard drive array
- Total Array Capacity
- 10 TB
- Interface
- Thunderbolt 2
- Installed Devices / Modules Qty
- 5 (installed) / 5 (max)
- Supported Drives
- SATA-600
- Storage Controller
- RAID (SATA 6Gb/s) - RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 5 x 2 TB HDD - hot-swap
- OS Required
- Apple MacOS X 10.9 or later
- Power
- AC 120/230 V - 50/60 Hz
- 17.3 cm x 19.6 cm x 22 cm
- 7.6 kg
- 3-year warranty
- Hard drive array
Chassis
- 5
- Supported Devices / Modules Qty
- 5
- Supported Drives
- SATA-600
Storage
- 10 TB
- HDD Array External Interface
- Thunderbolt 2
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Max Storage Devices Qty
- 5
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 5 x 2 TB
- Spindle Speed
- 7200 rpm
- Expansion Bays
- 5 (total) / 0 (free) x hot-swap - 3.5"
- 2 x Thunderbolt
- OS Required
- Security lock slot (cable lock sold separately), aluminum enclosure, Whisper Quiet Fan Technology
- Cables Included
- 1 x Thunderbolt cable
- Software Included
- Intego Backup Manager Pro, LaCie Private-Public, LaCie RAID Manager
- AES-256
- Power Device
- External power adapter
- Voltage Required
- Power Provided
- 150 Watt
- 17.3 cm
- 19.6 cm
- 22 cm
- 7.6 kg
- Limited warranty - 3 years
