The ECOSYS P5021cdw entry-level A4 color printer offers more than you could ask for. Despite its compact design, this economical color device includes plenty of valuable functions and achieves professional results with a resolution of 1,200 dpi. Features such as the duplex unit for double-sided printing or the direct printing functions (via Wi-Fi and USB host) keep your work running seamlessly. This reliable device is the perfect solution for small offices that set high standards.
- Up to 21 pages per minute in A4 in colour and b/w
- 1,200 dpi printing quality
- Wi-Fi and Wi-Fi Direct as standard
- Mobile printing support including AirPrint, Mopria, KYOCERA Mobile Print
- Compact design with low-noise printing
- Direct printing from USB flash memory
- Standard duplex unit for double-sided printing
- Exceptionally low printing costs in its class
Why choose KYOCERA?
- Kyocera ECOSYS P5021cdw - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 21 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 21 ppm - B/W - A4 (210 x 297 mm) , Up to 21 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 9600 x 600 dpi
- Max Resolution (Colour)
- 9600 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host, Wi-Fi
- Processor
- 800 MHz
- RAM Installed (Max)
- 512 MB (512 MB)
- Card Reader
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, PDF, XPS
- Barcodes
- PDF417, EAN-128, EAN-8, EAN-13
- Media Type
- Plain paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 50-sheet multipurpose tray, 250-sheet paper cassette
- Networking
- Print server
- Printer Features
- Toner Save mode support
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.8 or later
- 2-year warranty
- 41 cm x 41 cm x 32.9 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- 9600 x 600 dpi
- 9600 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 11 sec
- First Print Out Time Colour
- 12.5 sec
- Fonts Included
- 93 x scalable , 1 x bitmapped , 45 x barcode
- Barcodes
- Printer Features
- Media Handling
- Processor
- 800 MHz
RAM
- 512 MB / 512 MB (max)
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Thickness Range
- Up to 0.11 mm
- Media Weight
- 60 g/m² - 220 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 550 sheets
- Output Trays Capacity
- 150 sheets
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 1200 pages ISO/IEC 19752 , 1 x toner cartridge (cyan) - up to 1200 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 1200 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 1200 pages ISO/IEC 19798
- ISO 9001, ISO 14001, AS/NZS 3260
- Power Device
- Power supply - internal
- 345 Watt
- Power Consumption Stand by
- 33 Watt
- Power Consumption Sleep
- 0.9 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 2 years - on-site
- Sound Emission (Operating)
- 48 dBA
- 41 cm
- 41 cm
- 32.9 cm
- 21 kg
Kyocera TK-5230C Cyan Toner Cassette | In Stock | £76.53 |
Kyocera TK-5230Y Yellow Toner | In Stock | £76.53 |
Kyocera TK-5220K Black Toner Cassette | In Stock | £42.78 |
Kyocera TK-5220C Cyan Toner Cassette | In Stock | £56.32 |
Kyocera TK-5220M Magenta Toner Cassette | In Stock | £54.60 |
Kyocera TK-5220Y Yellow Toner Cassette | In Stock | £54.60 |
Kyocera Black Toner Cassette 2.6K | In Stock | £52.02 |
Kyocera Cyan Toner Cassette 2.2K | In Stock | £76.53 |
Kyocera Magenta Toner Cassette 2.2K | In Stock | £76.53 |
Kyocera Yellow Toner Cassette 2.2K | In Stock | £76.53 |
Kyocera TK 5220K Black Original Toner Cartridge | In Stock | £40.82 |
Kyocera TK 5220C Cyan Original Toner Cartridge | In Stock | £52.51 |
Kyocera TK 5220M Magenta Original Toner Cartridge | In Stock | £52.51 |
Kyocera TK 5220Y Yellow Original Toner Cartridge | In Stock | £52.51 |
