Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
This memory is designed for the following systems:
HP ProLiant ML370 G4;
HP ProLiant DL380 G4.
- Kingston - DDR2 - kit - 4 GB: 2 x 2 GB - DIMM 240-pin - 400 MHz / PC2-3200 - registered
- Product Type
- Memory kit
- Capacity
- 4 GB: 2 x 2 GB
- Memory Type
- DDR2 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 400 MHz (PC2-3200)
- Single rank, registered
- Voltage
- 1.8 V
- OEM Manufacturer Equivalent Part Number
- HP 343057-B21
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Designed For
- HPE ProLiant DL140 G2, DL380 G4 High Performance, ML370 G4, ML370 G4 High Performance
- Capacity
- 4 GB: 2 x 2 GB
- Upgrade Type
- System specific
- HP 343057-B21
- DRAM memory kit
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Voltage
- 1.8 V
- Compatible Slots
- 2 x memory - DIMM 240-pin
- Designed For
